VideoHelp.com Forum
Page 7 of 7
FirstFirst ... 5 6 7
Results 181 to 205 of 205
  1. Member DJRumpy's Avatar
    It's highly unlikely that a 2 channel source is encoded at 448 kbps. It's more likely its 5 channel audio. I agree. If you simply muxed your audio from the dvd using VirtualDub, it is identical bit for bit to your source DVD's audio.
    Impossible to see the future is. The Dark Side clouds everything...
    Your latest file has 5.1 AC3 audio. The video aspect ratio is wrong though. Just eyeballing it:
  3. Member DJRumpy's Avatar
    Good catch. It's too tall. Looks like it was cropped from DVD but not resized properly.
  4. Member ATLien's Avatar
    Anyone even thought about updating this guide, so it can coincide with the newer apps., or components the have came out, or have been updated, such as VirtualDub & Mod, Xvid 1.2.1., etc?
    Its confusing trying to use this guide when it talks about using older apps for it.
  5. Member DJRumpy's Avatar
    I'm surprised people are still using this one. I created it years ago. I'll see about updating it this weekend if I have time.
  6. Member DJRumpy's Avatar
    There are no appreciable differences in the version of virtual dub used in this guide and the XviD 1.2.1 configuration appears to be the same as far as I can see. If you have any specific examples, I'll be happy to update it.
  7. Member ATLien's Avatar
    What about the DGMPGDec? I have the latest and greatest, and I wasn't too sure there either.
    You said you were surprised about people using it? Ive been trying to find a more updated guide for this procedure, to no avail.
    Is there now a better and more up to date way of way, other than this guide?
    Thanks for your help.
  8. Member DJRumpy's Avatar
    There are numerous guides, each with it's own merits, difficulties, and issues. You can try any of them that you like in the How To section. Just search for DVD to AVI in the How To.
    Isn't this what the original Gordian Knot does?? (Not AutoGK)
  10. Member DJRumpy's Avatar
    Actually when this guide was created, Gordian Knot wasn't as popular as it may be now. It's also here for people that want to learn what happens behind the scenes with various tools.
    There is no single 'best' path to get from Point A to Point B. Use what works best for you, be that Gordian Knot or whatever that may be.
  11. Member darkdream4's Avatar
    Im lost when we get to the AVISynth steps. I installed it but I dont see any program or .exe its all just wierd files and plugins. I dont even know how to get AVISynth open. My guess is somehow the notepad program is now AVISynth or associated with it but I dont see how to use it. Can you explain it a little for me please?
  12. I'm a MEGA Super Moderator Baldrick's Avatar
    AVIsynth is no program you run, you just make avs text scripts. http://avisynth.org/mediawiki/Main_P...h_-_start_here
    Maybe you should use another dvd to xvid method....like AutoGK, Staxrip, Xvid4Psp. They do everything for you. 8)
  13. Member darkdream4's Avatar
    I would but I wasnt a noob back in 2006 when I used to do this. I havent done it in about 4 years and forgot alot. Ive done nothing but hear about AVISynth since I started and I really wanna study it and get to use it because of the customization it gives you.
    Thanks for the info though!!
  14. Member DJRumpy's Avatar
    AVISynth is easy. Just open notepad, and put in the scripts for whatever guide your using, and save it as a script.avs. It should play in Media Player just like an AVI.
    The most basic script is called Version()
    I'd suggest you start there. There are also some really great guides for it in the guides section. It's a powerful tool, and one that is essential if you plan to do any serious time with video editing
    If you get stuck, just post in the forums for help.
    Try AvsP as an editor for AviSynth scripts.
    Hi DJRumpy,
    Do we have to keep all the files same folder (Pick a directory to place your project files, and save the project file in that directory. Call the file "DVD2AVI.D2V") files like movie.avs, dvd2avi.d2v, VTS_01_1.VOB.
    Please clarify the directory for all the files we are going to make in the conversion process.....
    Please help....
    I am stuck at AviSynth script process......
    I am not able to preview the movie using "movie.avs" script as per the guide. I am getting error "Evaluate: System Exception - Access Violation".
  18. Member
    Hi,
    Please find below the text of my DVD2AVI.d2v file.
    Also find attached herewith the "movie.avs" and Screenshot of the error i am getting while playing the "movie.avs" file in Windows Media Player.
    I am new to this encoding please guide me step-by-step......
    As per your guide, In the "Movie.avs" file i have written only this....
    MPEG2Source("dvd2avi.d2v")
    DGIndexProjectFile16
    1
    C:\Movies\TRANSFORMERS2_D1_EL\VIDEO_TS\VTS_08_1.VOB
    Stream_Type=1
    MPEG_Type=2
    iDCT_Algorithm=1
    YUVRGB_Scale=1
    Luminance_Filter=0,0
    Clipping=0,0,0,0
    Aspect_Ratio=16:9
    Picture_Size=720x576
    Field_Operation=0
    Frame_Rate=25000 (25/1)
    Location=0,0,0,3abd96
    d00 5 0 2048 0 9 1 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 65536 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 147456 0 9 1 72 72 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 784384 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 f2 f2 e2
    900 5 0 1243136 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 1460224 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 1726464 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 2037760 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 2349056 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 2697216 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 3319808 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 3821568 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 4331520 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 4843520 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 5353472 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 5881856 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 6412288 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 6762496 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 7000064 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 7307264 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 7811072 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 8333312 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 8835072 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 9338880 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 9840640 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 10342400 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 10852352 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 11354112 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 11855872 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 12361728 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 12859392 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 13359104 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 13860864 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 14374912 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 14866432 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 15364096 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 15902720 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 16435200 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 16965632 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 17383424 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 17627136 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 17930240 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 e2
    900 5 0 18200576 0 9 1 72 72 d2 f2 e2 f2 f2 e2 e2 e2
    d00 5 0 18587648 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 19120128 0 9 1 d2 e2 e2
    d00 5 0 19247104 0 9 1 d2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 19324928 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 19542016 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 19785728 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 20099072 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 20721664 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 21250048 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 21786624 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 22036480 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 22276096 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 22554624 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 22837248 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 23117824 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 23402496 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 e2 e2
    900 5 0 23728128 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 24203264 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    d00 5 0 24596480 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    d00 5 0 25065472 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 25475072 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 25964544 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 26484736 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 27031552 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 27602944 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 28153856 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 28659712 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 29157376 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 29677568 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 30158848 0 9 1 d2 e2 e2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 30576640 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 30976000 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 31363072 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 31733760 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 32047104 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 32342016 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 32657408 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 32968704 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 33286144 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 e2
    900 5 0 33587200 0 9 1 72 72 d2 e2 f2 f2 e2 e2 e2 e2 e2
    d00 5 0 34144256 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 34652160 0 9 1 d2 e2 e2 e2 e2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 34961408 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 e2 e2 e2
    900 5 0 35319808 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 35926016 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 36495360 0 9 1 d2 e2 e2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 36827136 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 37185536 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 37564416 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 37937152 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 38328320 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 38731776 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 e2 e2 e2
    900 5 0 39182336 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 39763968 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 40296448 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 40810496 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 41336832 0 9 1 d2 e2 e2 f2 f2 e2 f2 f2 e2 e2 e2 e2
    900 5 0 41779200 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 42303488 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 42807296 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 43321344 0 9 1 d2 e2 e2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 43579392 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 43886592 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 44222464 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 44576768 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 44910592 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 e2 e2 e2
    900 5 0 45326336 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 45916160 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 46454784 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 47003648 0 9 1 72 72 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 47439872 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 47986688 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 48287744 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 48556032 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 48861184 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 49182720 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 49489920 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 49795072 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 50104320 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 50409472 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 50720768 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2 e2
    d00 5 0 51050496 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 51664896 0 9 1 d2 e2 e2 e2 e2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 52121600 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 52375552 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 52688896 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 52994048 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 53311488 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 e2
    900 5 0 53624832 0 9 1 72 72 d2 e2 f2 f2 e2 f2 f2 e2 e2
    d00 5 0 53932032 0 9 1 d2 f2 e2 e2
    d00 5 0 54163456 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 f2 e2
    900 5 0 54657024 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 54947840 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 55212032 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 55527424 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 55840768 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 56150016 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2
    900 5 0 56395776 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2
    d00 5 0 56659968 0 9 1 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 56875008 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 57161728 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 57432064 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 57716736 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 57978880 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 58243072 0 9 1 72 72 d2 f2 f2 e2 f2 e2 e2 e2 e2 e2
    900 5 0 58683392 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 59252736 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 59787264 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 60336128 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 60796928 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 61296640 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 61841408 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 62357504 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 62758912 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 63340544 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 f2 f2 e2
    900 5 0 63873024 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2
    900 5 0 64350208 0 9 1 72 72 d2 f2 f2 e2 f2 f2 e2 e2
    900 5 0 64770048 0 9 1 72 72 d2 f2 e2 f2 f2 e2 f2 e2
    d00 5 0 65183744 0 9 1 d2 e2 e2
    d00 5 0 65335296 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 65746944 0 9 1 d2 e2 e2 f2 f2 e2 f2 f2 e2 f2 e2
    900 5 0 66119680 0 9 1 72 72 d2 e2 f2 f2 e2 f2 f2 e2 f2 e2
    d00 5 0 66574336 0 9 1 d2 e2 e2 e2 e2 e2 e2 e2 e2 e2
    900 5 0 67067904 0 9 1 d2 e2 e2 e2 ff
    FINISHED  100.00% VIDEO
    Pls. help me.....
  19. Member leghorn's Avatar
    Not sure about the MPEG2Source command, if that is still in use. Maybe you should read the wiki/documentation at avisynth.org.
    For me, I dont create .avs files via notepad. I use DGIndex and MeGUI. Once I've created the .d2v file I load it in the Avisynth Script Creator of MeGUI and have a number of processing options (resizing, cropping, deinterlacing etc.). The output of such an avisynth script looks like this for me:
    LoadPlugin("D:\Multimedia\meGUI\tools\dgindex\DGDecode.dll")
    DGDecode_mpeg2source("D:\Filme\Sledge_Hammer\no_23 - a clockwork hammer.d2v", info=3)
    LoadPlugin("D:\Multimedia\meGUI\tools\avisynth_plugin\ColorMatrix.dll")
    ColorMatrix(hints=true, interlaced=true, threads=0)
    LoadPlugin("D:\Multimedia\meGUI\tools\avisynth_plugin\TIVTC.dll")
    tfm(order=1).tdecimate(hybrid=3)
    crop( 14, 6, -10, 0)
    Spline64Resize(704,528) # Spline64 (Sharp)
    #denoise
  20. Member DJRumpy's Avatar
    Your files don't have to be in the same directory, but it's easier if you do keep them in the same folder. If you do not, then you can just specify the path to files like your .D2V file like so:
    MPEG2Source("C:\somefolder\somefile.d2v")
    Your issue is not due to an invalid path. it is more likely due to an issue with your AVISynth install or a codec issue. Ensure you have the latest version of AVISynth installed and you should probably refresh your codecs. I'd suggest you try FFDSHOW Tryouts: http://ffdshow-tryout.sourceforge.net/. It should be adequate for most decoding needs.
    #denoise
    Hi Leghorn,
    Thanks for your suggestion.....
    I used the DGIndex and MeGUI to make the AVS Script and configured the XviD Encoder as per the Guide. And Finally made my first DVDRip using, DVD Decryptor, DGIndex, MeGUI and VirtualDubMod..
    Although the quality is not upto the mark as i expected...But still i just got a feel of the whole process from DVD to AVI using XviD encoder....
    Thanks to you.
    @DJRumpy thanks for this nice and useful Guide. I request DJRumpy to update the Guide as there might be something new in Video Conversion since 2004....
  22. Member DJRumpy's Avatar
    I tested with AVISynth 2.58.
    MPEG2SOURCE is still supported, and still works without issue. Your problem lies elsewhere.
  23. Love the guide vdub has been updated and xvid is still in development is there any settings in vdub that would not apply
    with the latest vdub thankx
    Virtual Dub 1.9.11 _ 24.12.2010
  24. Member DJRumpy's Avatar
    The basic components of VirtualDub haven't changed in a decade. If you happen to spot something that has, please me and let me know.
  25. Is there any way to test best compressability for xvid.
  1. Replies: 1
    Last Post: 26th Feb 2010, 08:12
  2. Check Over My Options From DVD to XviD Conversion Thread
    By adalect in forum Newbie / General discussions
    Last Post: 9th Feb 2010, 20:24
  3. Ripped dvd conversion to xvid/divx weird audio problem
    By victoriabears in forum Video Conversion
    Last Post: 12th Feb 2009, 13:41
  4. dvd to xvid conversion problem
    By dominator007 in forum DVD Ripping
    Last Post: 19th Nov 2008, 15:33
  5. Xvid to DVD conversion
    By Meriks in forum Authoring (DVD)
    Last Post: 5th Apr 2008, 10:43
