I would like to try including surround sound effects in my next home video using Pinnacle Studio 9. Because of the instability in Pinnacle products my processs has been to capture and edit in Studio 8 (and now 9) and then render to an uncompressed AVI file. From there I encode using either TMPGE or Mainconcept and then author and burn in TMPGE DVD Author. When I encode the file I usually use MPEG 1 layer II audio.
My questions regarding Pinnacle's surround sound are:
1) Will I keep the surround effects when I render to the uncompressed AVI file? (Or do I have to actually burn the disk using Pinnacle...which I haven't had much success doing)?
2) If the AVI file does keep the surround effects will I then lose the effects when I encode using MPEG layer II audio?
Thank you for your answers and opinions.
Vanster
anyone?
I'm a Vegas user, so this may or may not help. I use Vegas for doing surround audio using the AC3 encoder. I always render it out seperately as an AC3 file, then mux it back in later when authoring the disk. That way I know that the surround will be preserved. I don't know if studio 9 support AC3 (at 5.1 or EX), but if it supports mpeg audio, I would render it out as a seperate file for muxing later. At least you guarantee you keep your mix.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 21:03 -
Lg ht 355sd surround sound
By byrnech in forum DVD & Blu-ray PlayersReplies: 5Last Post: 27th Oct 2011, 05:08 -
corel video studio 12 5.1 surround headscratcher
By romanticwarrior in forum Authoring (Blu-ray)Replies: 1Last Post: 3rd May 2011, 05:33 -
Trying to get surround sound from RipBot
By Sutekh in forum AudioReplies: 2Last Post: 25th Aug 2009, 09:32 -
5.1 Surround Sound on DVD
By Adhishyajnik in forum Authoring (DVD)Replies: 1Last Post: 15th Jun 2007, 01:57
Statistics
Newest guides
Latest tool updates
New media comments
