I ripped the DVD with DVD Decryptor, Then opened it using DVDShrink (latest version) and it Automatically set the compressions so that the whole DVD would fit a 4.7GB Disc. Well then I tried to do some custom compression and now can't get it to go back to the 4.7GB size when I set everthing to Auto Compression.
I tried closing DVD Shrink and open it again and load the movie but it seems to remember the settings. Can someone tell how I can get it do the Auto Compression to get back to 4.7GB size?
Also how can I get DVDShrink to reopen a DVD from HD as though doing it for the first time? (i.e. where does it store settings for each DVD, which I can delete?)
http://www.dvdshrink.info/guides.php
look in preferences under edit
i don't use the latest version of dvdshrink so check the link above.
you could use a older version of dvdshrink, here's the link for older version:
http://mrbass.org/dvdshrink/dvdshrinkold/
Already looked in Preference and couldn't see any setting to reset so that orignal compressions are set.
then try using a older version of dvdshrink, some have problems using the latest version.Already looked in Preference and couldn't see any setting to reset so that orignal compressions are set.
I also had the older version and did not see anything in the preference to start over on a DVD. May be I might not have explained the issue properly, but I'm just trying to get to the stage as though I'm opening the DVD files for the first time and DVD Shrink calculates the compression automatically to the 4.7GB size. Once you make compression changes it obviously storing that info somewhere so I knew where that is maybe I can delete that.
I set target size to 4,300MB in Preferences(max. is 4,464MB).
The analysis file is kept in the Application Data folder(Explorer->Windows or Program Files folder).
Merge MTS/AVCHD and compress/shrink
By worm9110 in forum Video ConversionReplies: 1Last Post: 5th Dec 2011, 13:08 -
Will DVD Shrink shrink an ISO image?
By brassplyer in forum DVD RippingReplies: 4Last Post: 30th Sep 2011, 03:46 -
Digital8- capture and compress in real time OR shrink result to MKV
By auilani in forum Camcorders (DV/HDV/AVCHD)Replies: 4Last Post: 26th Sep 2010, 18:54 -
How to get Shrink to auto open Imgburn?
By PGibbons in forum Newbie / General discussionsReplies: 3Last Post: 12th Jun 2008, 23:15 -
how to shrink a movie with DVD Shrink?
By php111 in forum Newbie / General discussionsReplies: 2Last Post: 22nd Aug 2007, 17:59
