What do i need to do to stop the various "pop-ups" that appear when i've logged on in XP?
Results 1 to 9 of 9
What kind of pop-ups are they? Are they adverts or system errors?
You could try running Lavasoft Ad-Aware - do make sure it's fully up-to-date. This should sort your problem out if it's advertising or spyware.
Good luck,
Cobra
use mozilla firefox - it prevents popups
they're not pop ups as in the internet adverts, but regarding programmes/ software i have installed. I was told how to do it a whiile back in windows, but can't remember what i did- i didn't need other s/w to get rid of them though
Do you mean disabling XP's balloons?
go here: http://www.techtv.com/screensavers/w...362976,00.html"A beginning is the time for taking the most delicate care that the balances are correct."
- Frank Herbert, Dune
Nah, its not the message ballons, but the programme "pop up" messages like i said. Its more irritating than anything
You will have to go into the preferences for each program and tell it not to display a startup screen.
This is assuming you're talking about program popups like Antivirus...ZoneAlarm....etc.
I'll have a go at doing that but I'm sure that when i did it before i had to change an option in XP and not the individual progs that pop-up.....
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Attempting to demux VOB gives pop-up "file error" window eight ti
By taa in forum ffmpegX bugs and suggestionsReplies: 6Last Post: 31st Aug 2008, 02:02 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
