My new drive, the Memorex True8X, came with the Nero 6 OEM suite. Now, none of the discs I burn on DVD+R media will play, while burning the same exact data files to a DVD+RW disc play just fine. (Both media are also Memorex, and both worked fine under Nero 5.5 with my previous drive.)
Any ideas? (I've already checked for firmware and software updates.)
Rick
Thread: Nero 6 OEM
Tried burning at lower speeds?
do you have both versions of NERO installed on your pc? try uninstalling the NERO 6 OEM that came with your memorex drive and just use version 5.5
I did try burning at 1x and 2x, no luck. I also used the Nero cleaning utilities to strip off everything so I could get a clean install. Same problem.
The problem, however, has been solved, and this drive will be going back to the store on Monday (for a variety of reasons) in favor of an HP:
http://www.videohelp.com/forum/viewtopic.php?t=221328
OEM versions of certain software
By turk690 in forum ComputerReplies: 1Last Post: 2nd Dec 2010, 19:19 -
WinDVD 4 OEM - where to find it?
By mate in forum Software PlayingReplies: 4Last Post: 19th Apr 2010, 07:42 -
Retail vs OEM
By bryankendall in forum ComputerReplies: 5Last Post: 3rd Dec 2009, 11:32 -
windows 7 - oem or retail
By alintatoc in forum ComputerReplies: 29Last Post: 24th Oct 2009, 00:05 -
OEM vs Full Version
By bevills1 in forum ComputerReplies: 10Last Post: 23rd Jun 2009, 22:58
Statistics
Newest guides
Latest tool updates
New media comments
