Pioneer DVD-R DVR-106D
Latest Firmware - 1.07
I can record DVDs. Windows XP shows the drive in Explorer as "CD Drive". If I select properties, it shows the Pioneer DVD-RW 106D correctly.
When using DVDShrink, it does not see the drive at all. I have tried to uninstall and reinstall the drive but I get the same results.
Nero also burns the DVDs but reports the drive as "CD-R".
How can I get my PC to see the drive as a DVD-RW like it used to under Win2k?
did you update the Xp ? usually you need the Service pack for a lot of things to work properly....
windows update may solve ur problem, it sounds similar to a few problems I have had in the past with the aspi and win xp...
if windows update doesn't fix it, try using an aspi manager... you can get one from http://www.communica.com/downloads.html (i havn't used it but it comes highly reccommended).
Hope this helps!
I don't think it has anything to do with ASPI. Have you tried checking to see if your burner is DMA enabled? Here's a link on how to check DMA mode & how to set to DMA: http://www.cdrlabs.com/phpBB/viewtopic.php?t=9668How can I get my PC to see the drive as a DVD-RW like it used to under Win2k?
I tried to install the ASPI download but it failed with an error code of -42.
DMA is enabled.
Any other ideas?
Download ASPI from this site: http://www.adaptec.com/worldwide/sup...dkey=ASPI-4.70I tried to install the ASPI download but it failed with an error code of -42.
If the above one doesn't work then download forced ASPI from here:
http://www.doom9.org
go to downloads section & you'll see the FORCED ASPI 1.7
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Newbie / General discussionsReplies: 1Last Post: 31st Oct 2009, 19:48 -
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 17:26 -
DVD media no longer recognized.
By dymx in forum DVD & Blu-ray WritersReplies: 7Last Post: 16th Jun 2009, 18:01 -
Erased -RWs no longer recognized - HELP!
By will7370 in forum Newbie / General discussionsReplies: 6Last Post: 5th May 2009, 18:08 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 06:02
