VideoHelp.com Forum
    i have 2 avi files which need to be joined together, i have various joining programmes but all of them say the same thing, that the audio bitrate is differant for each file and that it canot merge because of this, is there a way i can join my avi files with video and sound, i know how to merge the video files, i extracted video with vdub and ran both files through a merging programme and it worked without sound, but how can i join the 2 sound files? currently they are in wav format, one is 256kb/s the other is 192kb/s, can i somehow join these files? ready to convert to ac3 using ffmpegui?
  2. Member bugster's Avatar
    They are likley not wav files with those data rates. They may be mp3 (or some other compression type) files with wav headesr and wav extensions.
    Open them in goldwave, then 'save as' to a new file. Ensure you set the type to wav audio, 48khz for DVD or 44.1khz for (S)VCD and let it save. These files can then be joined in goldwave, each file should be a lot larger than its original if my theory regarding the rates being wrong for wav files is correct.
  1. AC3 to WAV = Wav has no audio??
    By RobV in forum Audio
    Last Post: 31st May 2010, 15:26
  2. merging .264 with ac3 with mkvmerge goes out of sync
    By jylau125 in forum Video Conversion
    Last Post: 5th Nov 2009, 01:55
  3. AC3 to 6 Channel Wav
    By RabidSmurf in forum Audio
    Last Post: 11th Jan 2009, 11:52
  4. 5.1 Wav to AC3
    By markjwiggins in forum ffmpegX general discussion
    Last Post: 21st Dec 2007, 14:44
  5. AC3 to WAV (MUST KEEP 6 CHANNELS)
    By RushMaster in forum Audio
    Last Post: 17th Oct 2007, 04:03
