VideoHelp.com Forum
  1. Hi everyone
    OK I'm pretty new with all of this VCD authoring, and need some help now.
    I am in the process of capturing all of my laserdiscs and put them on VCD format. No films, most of them collections of videoclips and concerts.
    Most of them are not longer than 70 minutes, so I already captured several of them with VirtualDub, started frameserving and encoded them with TMPGEnc (BTW, I'm using "Low Quality" (Fast encode), as I don't see any difference between high and low quality processes' results on my 29 inches TV (Sony).
    OK, when I get the MPEG, I simply create (on concerts) cuepoints with TSCV and burn the CUE/BIN file with XDuplicator. The result is really great. A compliant VCD that works perfect in my standalone Phillips 951 Player.
    OK..., now the problems:
    Some laserdiscs are recorded on both sides: half the concert on each side, so I need to "join" the MPEGs.
    I guess (not sure about this though) that joing the captured AVIs is not possible since they are 2 GB each. So I guess my only option is to work with the resulting MPEGs.
    OK, so the first question is:
    Which program would be the easiest (and hopefully the "best" regarding the quality of the result&quot to use to join two MPG files? No edition needed. Just join them in order to have one single MPG file of the whole concert to create the cuepoints.
    Well, that was my first question
    Second one: By joining MPGs, will I loose quality or is it possible that will loose video/audio synch?
    Now to the edit problem:
    Let's say I only need to "erase" 10-20 frames at the beggining or the ending of the MPG: which program would be the best to do this? Just select them, erase them and get the new mpg file without those frames.
    And finally: in case I want to "fade in" and "fade out" not only AUDIO on an mpg, but also VIDEO (this is called a "transition" I think... not sure though): which program I should use?
    OK..., those were the questions
    Regarding the programs I have, I have almost downloaded them all, and "almost" all are fully functional now. I even have Premiere 5, Premiere 6, Unlead Media Studio Pro 6.0, etc.
    Hope any of you can help me))))))
    Thank you SO VERY MUCH) I'll be waiting online for your help to arrive}
    Mariano
  2. best mpeg converter is going to be tmpgenc as you can resize, whereas cce 2.5 you can't and it's free..
    splitting/joining. use myflix 3.05 (think it's the latest version).. there's a great tutuorialon http://www.flexion.org
    under videocd cookbook..
  3. To join the avi's in vdub open up the first, then File>Append Avi Segment, framserve as normal.
  4. Thanks Hence I'll try that program
    Thanks Shabubu, but that wasn't the problem
    Any other help / answers to my other questions?
    Thank you all
    Mariano
  1. Replies: 0
    Last Post: 3rd Jan 2011, 23:35
  2. Looking For A Old .srt Joiner Program
    By madrichie in forum Subtitle
    Last Post: 19th Sep 2010, 06:02
  3. Any program to edit .ts or .m2ts files?
    By yic17 in forum Editing
    Last Post: 18th Jan 2010, 00:29
  4. video edit program
    By cunnie in forum Authoring (DVD)
    Last Post: 4th Oct 2008, 10:44
  5. Is there a program that can edit a DIVX file, but without the need to re-en
    By peggypwr1 in forum Newbie / General discussions
    Last Post: 29th Jun 2007, 17:40
