I tried to burn a couple of .mpg's and .avi's onto a Memorex dvd+r (4.7gb) and the freeware Nero program presents a popup message that says this disc isn't usable. That's the readers digest version. I had to wait about a half hour for it to tell me that. I then popped in a dvd+rw and the same message arose again. I've burnt with these disc before and never had a problem. Could someone help me out...please?
Thread: problem with burning with nero
First things first.
Are you using Nero trial version, or free version?
Are you using VCDEasy for making DVD's?
Are you trying to burn a CD image to DVD media?
http://www.videohelp.com/forum/index.php?c=5
nero trial version
I selected vcd from nero smartstrart under favorites category
I'm burning video clips around 10 minutes long
Now i've never personally used VCDEasy, but doesn't it only make VideoCD and SuperVCD?
The Image that it creates (Cue / Bin) is a CD image. CD's use a different file system than DVD's, i don't think you can burn output of VCDEasy to DVD media and expect it to work. The layout of the files on the disk is also different.
Now the latest Nero supposedly has the ability to make a hybrid disc, but since i'm still on Nero 5.5 i can't really help you with this. I'm not even sure that the function of that special disk is active in the trial version.
If your clips are only 10 minutes long, you can go with either VCD, or SVCD , but you have to burn it to a standard CD.
You can only make a VCD or SVCD with VCDEasy.
Well, That's the problem. You are trying to burn a VCD to a DVD, which won't work. Instead use a CD-R or CD-RW to burn your VCD with no problem.I selected vcd from nero smartstrart under favorites category
// Znooky
I've used nero before to burn to a dvd+r. I have it right next to me so I know it's possible. I have an entire movie I wanted to burn that was hour thirty minutes long. Is there any other selection I can make to burn to this dvd+r disc? I don't understand how you could burn these clip and vids any other way. If you can't use a vcd with a dvd+r then what selection can you make to burn onto a dvd+r?
I'm so happy. I figured out my problem. Being the newbie that I am I missed the obvious and most simple solution...all I had to do was select the dvd icon. I was on the cd icon and didn't see the dvd option in the upper right hand corner. Thanks for all that tried to help but the solution was staring me in the face.
What version of Nero are you using. If I remember correctly the first version of 6(6.0.0) had a problem writing to +R/RW. Try updating to the latest version.
Svcd Burning Problem with Nero 7
By Soixante in forum Authoring (VCD/SVCD)Replies: 4Last Post: 3rd Nov 2010, 11:59 -
Problem burning data DVD using Nero 6 burning rom
By thebluekey_17 in forum Newbie / General discussionsReplies: 3Last Post: 19th Feb 2009, 13:14 -
Noobish Nero DVD Burning problem (no space available for recording process)
By windowlicker in forum Authoring (DVD)Replies: 5Last Post: 29th Dec 2007, 20:49 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40 -
nero burning problem
By peterjitonks in forum Authoring (DVD)Replies: 2Last Post: 26th Aug 2007, 13:40
