VideoHelp.com Forum
Results 1 to 11 of 11
    My PC has been installing the same windows xp security update for several weeks or more. It's been installed a minimum of five time within the past three weeks. Does my OS have a, a, ,,,, god I can't say it a, a, a, a Virus? If so Norton has not detected it, but sumthins just not right.
    Big Government is Big Business.. just without a product and at twice the price... after all if the opposite of pro is con then wouldn’t the opposite of progress be congress?
  2. Banned
    turn off auto update. problem solved
    Well sure but thats like saying don't drive your car if your breaks don't work when the question is "whats wrong with my breaks".
  4. Banned
    the reason it keeps installing, is because you have autoupdate turned on.
    Well yea, guess you may be right. Autoupdate is broken
  6. Originally Posted by gitreel
    Yeah, but why would it keep getting the SAME update and installing it? corrupted installer? somehow being uninstalled?
    if u do turn of auto update, remember to visit ms update site and update manually, from time to time
    http://v4.windowsupdate.microsoft.com/en/default.asp
  7. Banned
    because the web site has determined your computer needs that update. It keeps finding it uninstalled so auto update downloads and installs it over again. Turning off auto-update will fix it.
  8. Originally Posted by gitreel
    I understand that, i'm just trying to figure out why this problem would occur...
  9. Banned
    are you uninstalling the update?
    I've never directly uninstalled the update however I think I may have done a system restore to a point prior to the update after heving performed the update. Maybe thats how the mess got started.
  11. Banned
    when you did a system restore, it went back to before that update. So auto update is going to download and install, because micromonkey has determined you need that update.
  1. Replies: 17
    Last Post: 8th May 2011, 15:52
  2. How to Update Your Duplicator's BIOS. you need to update
    By krrish in forum DVD & Blu-ray Recorders
    Last Post: 29th Apr 2011, 12:02
  3. Security update for Xvid
    By TBoneit in forum Latest Video News
    Last Post: 11th Jun 2009, 14:32
  4. Security Issue
    By PBear in forum SVCD2DVD & VOB2MPG
    Last Post: 16th Jul 2008, 05:38
  5. Best All-In-One Security Suite
    By Nitro89 in forum Computer
    Last Post: 29th May 2008, 19:35
