When I play some burnt DVD-Rs, the PS2 seems to play it fine, but at certain points it seems to crash and freeze. Nothing works, the controller or the remote, and can only be solved by restarting the PS2. Does anyone else have the same problem? Is there anyway of sorting it out?
Spikeh
Thread: PS2 Playback with DVD-Rs
Might be media, might be your backing up method, or the most likely possibility...its just the PS2. Its not a very good DVD player really. Try them out on a real standalone player, see how they look on it. I bet they'll play better, and most likely not freeze up.
Ahh, thanks, but I have no money for a standalone DVD player T_T It can't be the media or the encoding because it plays fine on the PC.
If you think you have it... but you don't.
If you don't think you have it... you still don't.
Thats the PS2 then. All I can tell you is either...deal with the glitchy playback of the PS2, watch it on your PC, or save up and grab a cheaper DVD player like an Apex or something. It won't cost you over $50 and it'll probably play almost everything you toss at it. If you watch a lot of movies, or own a lot of DVD's it is worth it to have a standalone player.
Its probably your media, are those -r or +r?
The Media is DVD-R (Minus), I'm planning to get a DivX player actually after I read about them. But I need some money first ^^
PS2 DVD Region Free Code
By THRobinson in forum Media Center PC / MediaCentersReplies: 0Last Post: 28th Dec 2010, 11:59 -
PS2 and DVD info from region1 moving to region 2. confussed totally here
By joelliott in forum Newbie / General discussionsReplies: 7Last Post: 14th Dec 2010, 15:52 -
Playing ripped dvd in ps2
By hrgrosskopf in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2008, 08:04 -
Pinnacle 11 - playback issues on DVD - rapid playback problems
By crven in forum Newbie / General discussionsReplies: 5Last Post: 15th Dec 2007, 09:19 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 11:07
