I have alot of rawstock that I need to burn to dvd. What I need to know is if there is dvd software that will allow me to record more than 1 tape before trying to close the disk out.
I'm looking for something that will allow me to do what a DVD Recorder deck will do. Allowing you to fill up the disk until you're ready to finalize it.
TIA for the help
KID
There is no software that will allow me to start/stop record to DVD with out finalizing for the PC?
Neo DVD can use a format called DVD VR which is supposed to do this. I had no success trying to use it. Instead what I do is to just save clips on my computer untill I have enought to make the DVD.
Video Capture software question
By kgingreen in forum Newbie / General discussionsReplies: 2Last Post: 25th Feb 2010, 13:07 -
Question about difference between direct capture and sound card recording
By jimdagys in forum AudioReplies: 3Last Post: 16th Sep 2009, 09:09 -
Question about software for K-World Video Capture Card
By cooper101 in forum Newbie / General discussionsReplies: 10Last Post: 31st Oct 2007, 13:49 -
DV Direct to DVD (DV Capture)
By coisty1856 in forum Camcorders (DV/HDV/AVCHD)Replies: 5Last Post: 13th Sep 2007, 14:15 -
Direct capture from the PC DVD player?
By hitman3000 in forum Authoring (DVD)Replies: 1Last Post: 2nd Jul 2007, 17:37
Statistics
Newest guides
Latest tool updates
New media comments
