VideoHelp.com Forum
  1. HI I have alot of anime divx and xvid files that are at a ratio of 640 x 480 and on the new Philips DVP 642 the subs are to far at the bottom of the screen. What ratio do I need to make them fit on the screen plus what program should I use that well keep the same file size. Ive tried Dr. Divx but it makes the file bigger. Please help
  2. if you're trying to convert to DVD, the file sizes are going to be much larger no matter what. You can just use TMPENGC which is free and use 'keep aspect ratio' option.
    The new file size are probably going to be at least 4 times as big (i think).
    I think you might be talking about playing xvid and divx with your dvd player, not mpeg2. If thats the case, I'm not really sure about a good program to just resize without reencoding and losing quality.
  3. for 640x480, use 4:3 aspect ratio for output
    i leave the aspect ratio on the advanced tab at 1:1 display
    and use center keep aspect ratio
    these settings are for tmpgenc encodes.
  4. Member mats.hogberg's Avatar
    If the subs are hard coded (not in separate file) there's nothing you can do, besides reencoding and adding a black border top & bottom. TVs always cut a piece from all sides - how much depends on make and model of TV. This is called overscan.
    /Mats
  5. If the subs are hard coded (not in separate file) there's nothing you can do, besides reencoding and adding a black border top & bottom. TVs always cut a piece from all sides - how much depends on make and model of TV. This is called overscan.
    yeah if you use center (keep aspect ratio) the overscan will cause the video to play full screen without cutting off any of the sides.
    I've learned the hard way about overscan.
  1. Replies: 1
    Last Post: 26th Feb 2010, 08:12
  2. Replies: 1
    Last Post: 9th Mar 2009, 13:52
  3. Problems playing Divx / Xvid files on Silvercrest KH 6508
    By Onihoshi in forum DVD & Blu-ray Players
    Last Post: 11th Oct 2008, 15:18
  4. Replies: 4
    Last Post: 5th Jun 2008, 11:47
  5. Replies: 6
    Last Post: 30th Jun 2007, 14:57
