    Jan 2004
    Alabama
    Hi All,
    What steps should I take to dub or mute over curse words on a DVD? I have TMPGEnc plus and Nero6. I can remove the words with TMPGEnc but it involves me cutting actual frames.
    Thanks in advance for replies.
  2. well your best bet is to demux the audio from the video. Convert the audio to a wav file (unless the audio program you use accepts ac3 or mpeg, etc), and "edit out" (or just replace) the words that way. Then remux the new audio back with your video. Now you do not have to cut frames from the film
  3. Here's a better idea: Don't buy or rent any films with curse words in them. Save yourself the trouble.
    Look, let me explain something. I'm not Mr. Lebowski; you're Mr. Lebowski. I'm the Dude. So that's what you call me. That, or Duder. His Dudeness. Or El Duderino, if, you know, you're not into the whole brevity thing--
