I am trying to assemble a DVD using TMPGenc DVD Author. I am using files that were encoded from DivX to MPEG format after extracting the AC3 streams with VirtualDub.
My problem is that some of the AC3 streams are 3-channel and others are 4 channel and TMPGenc DVD Author requires all the files on a track to be consistent.
Is there a way I can strip the extra channels from the AC3 files with 4 chanels or possibly add a blank 4th channel to the 3-chanel files so I can put them all on one DVD?
Thread: AC3 Channels
You could try GoldWave for this - I know that it supports AC3 and is described as a "semi-pro" editor. Give it a shot and see how it works.
Good luck,
Cobra
The other way is to put them on seperate tracks. Saves messing with the audio.
"Learn from other people mistakes , it's quicker"
I've tried using GoldWave but every time I try to open an AC3 file with it, it crashes with an error about neroadb.dll. I've tried uninstalling and re-installing several times and can't seem to fix the problem.
In the meantime, I have used the AC3Machine front-end for BeSweet to downmix the LFE channel into the Left and Right channels for my 4-channel files so they are left with 3 channels. (L+R+C). I'm about to make my first disk with the downmixed files so I'll report back with the results.
AC3 channels are split incorrectly
By silvertoaster in forum AudioReplies: 2Last Post: 23rd May 2011, 22:10 -
Is there a way to correct wrongly placed ac3 channels?
By Jo The Veteran in forum AudioReplies: 3Last Post: 4th Apr 2011, 11:54 -
Dolby AC3 5 channels - voices are not playing
By dexter30 in forum AudioReplies: 1Last Post: 28th Oct 2009, 16:58 -
MKVs: downmix ac3 6-channels to ac3 2-channels and remux
By kwanbis in forum AudioReplies: 4Last Post: 10th Mar 2009, 16:07 -
AC3 to WAV (MUST KEEP 6 CHANNELS)
By RushMaster in forum AudioReplies: 6Last Post: 17th Oct 2007, 04:03
Statistics
Newest guides
Latest tool updates
New media comments
