Hi, I'm trying to understand which are the 4 buttons (apart from numbers) that VCDeasy uses
- Previous
- Next
- Return
- Default
Could you please have a look at my diagram that maps VCDeasy to my 3 remotes and give me some tips
http://users.tpg.com.au/aclement/VCDeasy_Controls.ppt (137k)[/url]
Hi!
The Previous and Next options are the same as Previous and Next on your remote control.
The Return option is the same as stop on the remote and Default option represents Enter on the remote.
I haven't tested this myself, but take a look in the link below. Look at part 6d where it's descibed.
http://www.vcdeasy.org/modules.php?n...DVDRip_Extract
// Znooky
Thanks Znooky
It seems that on most DVD remotes, the VCD buttons are;
Next: 'Next' and/or '>>|'
Prevous: 'Previous and/or '|<<'
Default: 'OK' and/or '>' (play)
Return: 'Return' and/or 'stop'
Just enough to nagivate menus;
Next and Previous to nagivate menus
Default to play the item
Return to jump back to the menu
How to remove the remove redundant tracks of *.ts?
By UMO in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2010, 00:30 -
More than 12 buttons with dvdauthor
By PeskyJ in forum Authoring (DVD)Replies: 7Last Post: 17th Dec 2008, 16:50 -
Remove ads, subs and audio that I don't need and modify buttons
By Brent.M in forum DVD RippingReplies: 8Last Post: 13th Aug 2008, 10:38 -
Can you remove buttons from TDA?
By colt4523 in forum Authoring (DVD)Replies: 3Last Post: 12th Jul 2007, 03:51 -
Animated Buttons
By Paulodemoc in forum Authoring (DVD)Replies: 3Last Post: 27th May 2007, 15:39
Statistics
Newest guides
Latest tool updates
New media comments
