VideoHelp.com Forum
Results 1 to 15 of 15
  2. Member housepig's Avatar
    is this one of those "if a tree falls in the forest... " things?
    when is a question not a question?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
    Please ignore my pointless reply.
    Yes! Because ....
  6. Marmite & Custard.
    Stupid question, stupid answer.
    Cobra
    Truly a conundrum. If one posits that the question is indeed silly, then does the reader not take upon himself a measure of that silliness by stooping to answer? Would a sane viewer not choose to distance himself from the silliness so as to avoid its stain? But then again, is the silliness of the question not dissolved when a sane man stops to answer? By treating the question as serious and of worth does the viewer not automatically raise the question from the philosophical dust and imbue it with a luminous, almost heavenly, logical glow?
    Truly, does a serious answer not lift the question from the gutter of the unasked?
    Is any question not bettered in the uttering?
    And to you, my men, I say "YES!" Raise up those questions! Ask the unasked! Seek! Ask! Go forth and search out the knowledge that searches for you, and rise with me en masse, as a single voice, and say "NO, YOUR QUESTION IS NOT SILLY!
    Well, okay... maybe it's a little silly.
    Fight spammers ghetto kung-fu style! Join the Unsolicited Commandos! or the Spam Vampires!
    Sorry something went wrong but don't know what. The post should have read:
    Can anyone please help with this question?
    I have been getting to grips with the software that I have down loaded. I had earlier problem with TMPG and the Audio/Video bitrate settings but I have since overcome theses problems. What I would now like to know is if I change the video bitrate to the suggested figures given by the bite rate calculator, which incidentally would put the file at over 4.7 GB. Could I then use shrinkdvd to put it on a dvd or would this just reduce the quality back to what it was before I’d spent 4 hours running it through TMPG
    Towbar
    P.S sorry once again for the first post. But the replys have had me in Fits thanks for the laughs
    I liked your first question better
    Using DVDShrink is the first option I'd try.
    No need to reload TMPGEnc and start all over, unless you don't like the results you get from DVDShrink.
  11. TMPGENC is an encoder while dvdshrink is a transcoder. I dont know the specs of "over 4.3 gig" as in how much over. If the encoded file is a little bit over, then I think that dvdshrink would be just fine, but if it is say 8 gig and you want to shrink it down to 4.3, I dont believe that it would give you a better picture than if you just encoded to 4.3 in the first place. I have never done what you are trying so wouldnt hold a lot of stock in my reply.
  12. Originally Posted by elkfir
    It got a great response didn't it? All these closet comedians ......myself included
    Well yes Capmaster the mistake certaily generated a lot of response
    wish i could say i did it on purpose but the answers were just brilliant
    Towbar
    Murphy was an Optomist
  14. Originally Posted by Towbar
    Towbar
    Yep. I noticed that haloblack especially was flexing his philosophical sarcasm muscles ...what a post
    Yes Hands up to Haloblack the response was just perfect
    In view of his witty response and declaration that ""NO, YOUR QUESTION IS NOT SILLY!"
    Do you think I should title all my posts "Is This A Silly Question"?
    it certainly got me a quick response
    Merry Christmas to All lol
    Towbar 8) 8) 8)
  1. Ripping 50gb Silly Question
    By beric3236 in forum Blu-ray Ripping
    Last Post: 16th Nov 2009, 19:30
  2. Silly VideoLAN setup question
    By Ensign in forum Software Playing
    Last Post: 9th Dec 2008, 00:48
  3. Silly mkv format, hd question.
    By adkom in forum Newbie / General discussions
    Last Post: 9th Oct 2008, 04:36
  4. Silly question about cable modem and PC
    By cim in forum Computer
    Last Post: 7th Jul 2007, 18:15
  5. Silly Question About AnyDVD
    By hech54 in forum DVD Ripping
    Last Post: 10th May 2007, 01:29
