  1. Is there an adapter that allows me to connect from my video card (S-video, TV out) to the cable (coaxial) input on my TV? I would like to connect this TV for video editing. If so, how is the quality?
    The TV does not have any RCA jacks.
  2. Mod Neophyte Super Moderator redwudz's Avatar
    You can get a TV modulator at Radio Shack, for example that can take a TV compatible composite video signal (Not SVHS) and audio and output it to a TV channel, usually 3 or 4. If the video output from your card is made for TV or monitor use; It would work. Quality? Depends on your video card output quality. Not likely to be that great.
    Wal-Mart has a RF modulator from Philips that has both composite and S-video inputs and outputs. This should do the job for you. The cost is around $30.
  4. I believe they also sell a similar RCA model for only 20$
