  1. Here's a thread on another forum telling you how to check your firmware and it gives you the latest firmware in an all in one iso image (it's 45meg). There's several models:
    DT100:
    439
    LA95:
    233
    LX9:
    439
    RA60:
    050
    LV60/PV40
    133
    RV22/RV32:
    440
    RP62/CP67:
    073
    RV36/RP56:
    062
    HT65/HT70/RV31/RV41:
    397
    DM3/HT75/HT95:
    068
    CV52/DK20/HT67:
    082
    RA61/RP91:
    262
    CP72/RA82/RP82/XP30/XP50:
    302
    Denon DVD-1600:
    068
    To check firwmare:
    Hold PAUSE and OPEN on player and press 7 on remote. Last 3 numbers is your firmware.
    For reset sequence.
    Perform the following:
    1) On the unit
    - hold PAUSE + BWD-SKIP + OPEN for about 3 seconds
    The display will display "initialization" or "int".
    2) While initialization is being displayed, let go of PAUSE and press STOP while holding the other two buttons.
    The display will then display "reset".
    3) Set your user settings.
    Downloading the firmware:
    ISO image on first post of this thread:
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=378689
    I felt like it help the PQ on my RP56 and they may help in DVDr compatibility.
    Jul 2004
    So. CA
    Happy, HAPPY! I just tried this update on my old Panasonic RV32. It couldn't play Ritek (or any) DVD+R disks from my new 8X Plextor 708A (which of course doesn't support booktype bitsetting). Now it does! Woo hoo! Player was at firmware level 62B421, now 62B442. Thank you, Vanderlow, and Sango on AVS Forum! And, of course K. Timmerman at http://www.firmwareupdate.us
    If your Pany is having trouble with media, check this guy out. He wants a donation on PayPal (your choice of amount). I wasn't too sure about this, but for $2, hey... I bumped into somewhere you can find it for free via eDonkey(?), but I figure since this guy is for real, he's worth alot more than $2.
  3. what's the name of the iso file?
    Jul 2004
    So. CA
    Sorry, I haven't saved the original download. Try the AVS Forum at
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=405756
  5. I just tried this too. My RV32 DVD player would not play DVD+R of any kind. Now it does with no problems. Nice update for as low as $1.00.
    Here's how it works:
    Go to the link
    At the bottom of the page, click a Paypal donation amount as low as $1.
    After you donate, click continue.
    You will be at the download page.
    Select the download type you want.
    Burn it to a CD-R, not a DVD
    Insert in DVD Player and wait for the menu and click yes.
  6. does it make it SVCD support.
  7. Originally Posted by perry38
    I upgraded my player with the new firmware, but SVCD support still sucks.
    Its seems like everything else works alot better though. MP3 playback is no longer limited to 160 kBits/sec (it use to ignore these completely), and i've even had luck playing some VBR files.
    The player also use to stick for a split second on some scene changes, and now doesn't since the update.
    The player is generally more tolerant with the new firmware.
