VideoHelp.com Forum
Results 1 to 11 of 11
  1. I just got a NEC 2500a dvd 8x +r/-r/+rw/-rw and i'm learning how to do this dvd thingy.
    i was just wondering cause i have a few mini series of Japanese dramas and i want to put them all on 1 disc. If i burned a data dvd they would all fit, but can i put them all on 1 dvd and play the videos on my dvd player. There's about 11 files generally. If i convert them then it will fill the dvd with just one, if i lower the quality with that TMPGenc app then it looks like crap, they'd all fit then but idk. What do you all sugest? I know they sell these series on dvd's, maybe their like 9gb dual layer ones idk...
    thanks for your help
  2. Member pchan's Avatar
    If you encode to Divx format, then you can burn about 7hrs in one DVD disc (4.7G bytes). But you must have a DVD player that support Divx format before you do that.
  3. damn, i figured that dvds were kinda like vcd's, they go by the time not the file size
    i'll just burn to an iso and use my laptop to export the vid to my tv , thx for the help mate....now to get that blasted dvd burner to work ...
  4. Member teegee420's Avatar
    Alternatively you could re-encode your movies with TMPGEnc with a bitrate of around 2500kbps using a 352x480/576(480 for NTSC 576 for PAL) resolution and fit 3-4 hours one one DVD that will play in your DVD player. Or you can fit 7 hours by encoding as VCD and authoring to a DVD(just make sure you choose 48000hz as the audio sampling rate). It all depends on how much quality you are willing to sacrifice. Play with the numbers yourself by using the DVDRhelp Bitrate Calculator.
  5. ok, you mean encoding as vcd as in mpeg1? using tmpgenc right?
  6. Member teegee420's Avatar
    Yes. But as I said, make sure you select 48000hz as the audio sampling rate. The default VCD template value is 44100hz and is not DVD compliant.
  7. ok great i'll try it
    being that your a knowledable person, due to your post count , do you have any clue what is going here:
    http://www.videohelp.com/forum/viewtopic.php?t=219093
    i'm totally stranded
  8. Member teegee420's Avatar
    Don't let the post count fool you. I've been spending time in the "off topic" forum lately.
    I'm afraid I can't help you with your other situation. Be patient though. There are plenty of people around here that know more about those kinds of problems. Good luck.
  9. thx, i had good expectations about this whole dvd thing, but it's been a friggin nightmare so far , maybe it's my version of nero? I just flashed it with the "official" firmware i think, 1.06? lol
  10. so use tmpegenc to re-encode to vcd right? then use like dvd-lab to author and burn? I'll try it thx
  11. Member teegee420's Avatar
    That should work out fine. Even if you forget to set the correct audio sampling rate, DVD Lab will resample it for you.
  1. How to Cut & Merge mini 10 part mini series?
    By skorpinok in forum Editing
    Last Post: 8th Oct 2011, 09:41
  2. Replies: 0
    Last Post: 12th Apr 2011, 22:34
  3. How to burn tv series/burning audio books
    By jenny56 in forum Authoring (DVD)
    Last Post: 21st Apr 2010, 17:42
  4. Burning a series of film to a dvd disc
    By minhbola in forum Authoring (DVD)
    Last Post: 5th Jul 2007, 12:52
  5. Urgent Help! - Panasonic Mini DV NV GS series tape drawer problem
    By kwame in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 10th May 2007, 13:28
