This has probably already been posted, but what type of cloth/material is best to use when wipping off smudges/fingerprints?
I like to keep my dvd's spotless, but today I noticed one had alot of fingerprints over it so I decided on using a soft kleenex to clean it off, it worked okay, but I got a few scratches from it.
Any ideas?
Thread: Cleaning dvd's
Glass cleaner and toliet paper, low cost, works great for me!
Don't crinckle the paper/tissue up, just wipe it off starting from the center straight to the edge, and also don't make "circles" when your cleaning the disc, that will scratch it.
Stay away from kleenex or toilet paper. It can have abrasives mixed in.
Stick with a clean cotton cloth and window cleaner or eyeglass cleaner. Polycarbonate is tough stuff if you don't get organic solvents near it (lacquer thinner, gasoline, etc.). Those will melt the plastic on contact. Alcohol is OK but it streaks more than glass cleaner. Also ....rub lightly. Don't bear down or you'll get scratches.
personally, I use my shirt to clean dvdr's. Aint never had a problem. Dont use a 3 year old to help you clean them, however.
Those soft clothes in hotel bathrooms are great. Also photo cloths. Really cheap, not hard to locate. Even some t-shirts are fine.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
DVD Recorder Cleaning
By Maldez in forum DVD & Blu-ray RecordersReplies: 49Last Post: 2nd May 2012, 06:42 -
cleaning dvd's
By the_shyguy in forum MediaReplies: 25Last Post: 7th Dec 2009, 04:39 -
DVD cleaning/resurfacing
By rhuala2 in forum Newbie / General discussionsReplies: 12Last Post: 27th May 2009, 19:14 -
Cleaning a DVD??????? Best way???
By vbond0071 in forum Newbie / General discussionsReplies: 19Last Post: 24th Mar 2009, 18:33 -
DVD audio cleaning
By efiste2 in forum Authoring (DVD)Replies: 9Last Post: 10th Feb 2008, 10:46
