VideoHelp.com Forum
  1. If I use dvdshrink and only take out the main movie, set the settings to: "no compression" and backs up the dvd, do I get any quality loss from the original??
    I did'nt think that I would but when I pressed "backup" dvd shrink started to encode the dvd-file.. Why does dvd shrink do that? And don't I get a quality loss when the program encodes the dvd-file?
    Please help!
    /Johan!
  2. Member mats.hogberg's Avatar
    If you set q at 100%, I'm pretty sure (even if I haven't verified it) Shrink leaves the video stream as is. It never encodes (it transcodes) but at 100% the video will be untranscoded. What takes time might be other stuff like ripping, demultiplexing, remultiplexing and such.
    /Mats
  3. Member archaeo's Avatar
    That time is spent in removing the encryption.
  4. Thanks for all the answers!
    But when I loaded the file into dvd shrink I have allready decoded it with dvd decrypter.. So it sould not be the decryption that takes time, or??
    /Johan!
    It's stripping out all the stuff you chose to not keep and recreating the IFO's, BUP's, etc. This takes some time.
  6. If you set q at 100%, I'm pretty sure (even if I haven't verified it) Shrink leaves the video stream as is.
    that's correct, and easily verified. in PowerDVD (or whatever) play the original dvd and select the properties to be displayed along with the movie. take note of the bitrate. now play the UNcompressed shrunken dvdr and note the bitrate is the same. a transcoded file will have a reduction in bitrate.
  1. Quality loss from D V -AVI to other formats
    By santolina in forum Video Conversion
    Last Post: 24th Jul 2009, 14:24
  2. mkvmerge - no quality loss?
    By gustav32 in forum DVD Ripping
    Last Post: 20th May 2009, 14:56
  3. MKV to AVI without quality loss
    By Markomaani in forum Video Conversion
    Last Post: 15th May 2009, 09:51
  4. Encoder with no quality loss
    By JamesDV in forum Mac
    Last Post: 8th Apr 2009, 11:01
  5. video quality loss
    By majax79 in forum Video Conversion
    Last Post: 24th May 2008, 01:03
