Hi,
Bought the AC3 plugin for TMPGenc DVD Author. Installation succesful - have the logos and the extra options.
I added an M2V file created by TMPGenc and then attempted to add the AC3 file in the audio section.
Extracted the AC3 using vdubmod.
Why won't DVD Author accept it??
You only need the ac3 plugin if you are going to convert to AC3. Tmpgenc dvd author supports encoded ac3 audio files. Try repair the ac3 file with ac3fix or beslice(included in besplit).
Thanks Baldrick! That did the trick. Though ac3fix found nothing wrong with the file, the outputed file was accepted.
AVI (with Ac3 audio) to DVD using TMPGenc 2.5 Plus
By CaptainChaos in forum Authoring (DVD)Replies: 7Last Post: 2nd Mar 2012, 07:03 -
How to Author AC3 5.1 Channel Audio Only DVD Using DVDLab Pro 2
By Hittz in forum User guidesReplies: 10Last Post: 3rd Apr 2011, 00:05 -
TMPGEnc Authoring Works 4 (AC3 Plugin)
By likwid8 in forum Authoring (DVD)Replies: 1Last Post: 25th Oct 2010, 03:30 -
Long silence in ac3 is mysteriously shortened when I author
By Genaugmen in forum Authoring (DVD)Replies: 0Last Post: 20th Aug 2010, 16:47 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 19:22
Statistics
Newest guides
Latest tool updates
New media comments
