I record a film on HARD DISK (or DVD-RW), I make chapters in the commercial inserts and then I erase them.
During the play of the cleaned film, the point of the breaks, that is the LAST FILM FRAME before the erased insert, stays FROZEN in the screen for about one second before to continue with the next chapter, that is film continuation after the erased advertising.
Now, two questions:
- is the described occurence normal or my DVD RECORDER PIONEER
5100H is defective?
- if it is normal, is there anybody that can suggest me what I have to do
to eliminate this annoying problem.
Thank in advance, bye!
Sounds to me like you are DIVIDING the titles into separate chapters. This would cause the pause between chapters.
Its best if you just use "chapter edit" - press chapter mark at the start/end of the ads and then erase them.
I do this all the time. It can free up a lot of space eg the other day I reduced a 1hr 30min prog to just over an hour! And I dont get pauses where the Ive trimmed the ads out.
Also just wonder if you have "Frame Accurate" on or off?
B R
Pioneer DVD recorder
By cjones in forum Newbie / General discussionsReplies: 1Last Post: 11th Aug 2011, 06:14 -
Pioneer DVD recorder firmware
By jh76 in forum DVD & Blu-ray RecordersReplies: 1Last Post: 11th Apr 2009, 02:03 -
Hacking Pioneer DVR-5100H (DVR-510H)
By Destroyer in forum DVD & Blu-ray RecordersReplies: 145Last Post: 5th Mar 2009, 13:46 -
Removing CPRM on my Pioneer dvd-recorder 633, is this possible?
By mallanikkelsen in forum DVD & Blu-ray RecordersReplies: 1Last Post: 25th Jun 2008, 00:27 -
Which DVD Recorder to buy, Pioneer?
By J C in forum DVD & Blu-ray RecordersReplies: 71Last Post: 4th Jul 2007, 10:22
Statistics
Newest guides
Latest tool updates
New media comments
