VideoHelp.com Forum
  1. I'm using Sefy's guide to make VCD's after ripping a DVD. Everything was fine until I got to the step where I'm supposed to paste chapter information, the part in VCDEasy where I'm supposed to right click and then I click "Paste ChapterXtractor (RAW data)" but nothing happens.
  2. Member adam's Avatar
    Maybe its a silly question but, you did load the IFO into ChapterXtractor and copy your chapter points first right?
  3. Originally Posted by adam
    I'm not 100% certain but I do remember opening the text file made by ChapterXtractor and highlighted the chapter times, Ctrl-C, and tried to paste into VCDeasy.
  4. Member adam's Avatar
    I probably haven't used ChapterXtractor or VCDEasy in over a year, but looking back at my old guide, I just copied the chapter points directly out of ChapterXtractor. Maybe try doing it this way...
    http://users3.ev1.net/~CavemanLawyer/Vcdeasy.htm
  5. @nocarebear, have you marked ALL the contents of the text file that was generated by Chapter-X-Tractor ? Cause if you didn't, then the information will not be suitable. And that may be the cause of your problem.
    PS: Make sure the Chapter Information can be pasted from the Clipboard.
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  6. I'm back. I did get to paste the chapter information; I think I did something wrong the first time I did it.
    What I did was just highlight chapter information, copied, and paste in VCD Easy and that worked. But, wouldn't marking all the content of the text file create an error on VCD Easy because the text file includes non-numbers?
  7. I Think VCDEasy is designed to handle all the information in that text area
    Best Regards,
    Sefy Levy,
  1. Which paste to use on EVO and 960T?
    By Stealth3si in forum Computer
    Last Post: 27th Mar 2012, 21:53
  2. Can you convert a VOB file and keep chapter information?
    By woody777 in forum SVCD2DVD & VOB2MPG
    Last Post: 5th Mar 2010, 14:38
  3. Thermal paste...
    By kenmo in forum Computer
    Last Post: 3rd Apr 2009, 20:08
  4. This blue paste thing
    By vipertongn in forum Computer
    Last Post: 6th Feb 2008, 07:03
  5. VOB to MPEG2 with Chapter Information
    By badgerbrian in forum Newbie / General discussions
    Last Post: 4th Feb 2008, 14:11
