VideoHelp.com Forum
  1. Member wulf109's Avatar
    I bought this DVD player to watch DIVX files on TV and the DIVX files do look excellent. The problem I was having was "stumbling" in playback.
    It was random and seemed tied to bright scenes. I was using DIVX 5,Itried several versions of DIVX 5 with the same result.
    I downloaded DIVX 3 & 4 and found that DIVX 4 files play smoothly.
    At least in my expierence this player doesn't like DIVX 5.
    Another problem is AC3 audio,no file I've made with AC3 audio will even load,the player justs locksup. The exception are files made with AutoGK using AC3,they play. AutoGK will install an option to make it's output compatible with ESS chipsets,which this player uses. AutoGK however does not allow you to set the vertical resolution anf it always auto-selects a height which corrupts 4:3 aspect ratio.
  2. I don't have problems like You.My player play all Divx movies with AC3 audio.Also no problems with Xvid with AC3 audio.Only one Xvid movie don't play.Don't know why.
    The only problem I am having is with older divx 3 files not playing audio at all....just the video..
  1. Remote for Philips DVP642
    By Melina in forum DVD & Blu-ray Players
    Last Post: 10th Jun 2010, 21:54
  2. PHILIPS DVP642... how do I upgrade the firmware?
    By mummer43 in forum DVD & Blu-ray Players
    Last Post: 14th Jan 2009, 18:45
  3. Philips DVP642 DivX subtitles. WORK!!!
    By shrybouski in forum DVD & Blu-ray Players
    Last Post: 7th Aug 2007, 14:06
  4. Philips DVP642 and DivX 6/Ultra
    By cheerful in forum DVD & Blu-ray Players
    Last Post: 2nd Aug 2007, 11:43
  5. Problems with Disney/Pixar DVDs on Philips DVP642
    By deesto in forum DVD & Blu-ray Players
    Last Post: 28th Jul 2007, 19:11
