VideoHelp.com Forum
    When my source are 23,97 fps/44.1 KHz, do I have to convert the audio to 48 KHz when I'm going to burn the movie as a NTSC DVD?
    I've done this with a 29.97 fps/44.1 KHz, and I didn't get any a/v sync problems when burning it as a NTSC DVD....
    ...000....000....
    Angelot :-D
    The simple aswer is YES
    I don't know what you use to author your DVD but TMPGenc DVD Author will do it for you automatically.
    You wont get sync problem because of it . 48K is a sampling rate as is 44.1K . It has nothing to do with Bitrate or movie length.
    "Learn from other people mistakes , it's quicker"
  1. Replies: 10
    Last Post: 2nd Sep 2009, 03:04
  2. Converting PAL to NTSC and rip PAL Audio to WAV in VLC
    By happydog500 in forum Video Conversion
    Last Post: 8th Aug 2009, 01:47
  3. Converting PAL ISO to NTSC for DVD-Video
    By Nate7410 in forum Authoring (DVD)
    Last Post: 18th Sep 2007, 14:27
  4. converting PAL AVIs into NTSC DVD
    By exekutive in forum ffmpegX general discussion
    Last Post: 24th Jun 2007, 18:20
  5. Converting an NTSC DVD to PAL w/ DTS
    By thisismyname07 in forum Authoring (DVD)
    Last Post: 26th May 2007, 23:57
