I have a Philips 727 and am looking for a wide-screen LCD Monitor with progressive scan component input (preferably HD compatible, at least 720 lines).
My goal is to play PAL DVDs as PAL and NTSC DVDs as NTSC to avoid the conversion issues. Now I am wondering: Do I have to worry that the monitor is advertised to accept both PAL and NTSC or is that a moot point if I use the component video signal?
Any other thoughts, recommendations?
Yes, you do. Composite, S-video, and component only change the ways in which the video image data is carried from device to device (composite, separate Y/C, or separated RGB, respectively). The line count, frame rate, and sync signal timing will be maintained no matter which connection method you use -- PAL will still be 625 lines, 50 fields (25 frames) per second, NTSC will still be 525 lines, 60 fields (30 frames) per second, and your display device will still need to be able to cope with both sets of horizontal and vertical sync timings to be able to play both kinds of video.
all LCD monitors ive seen except both pal and ntsc ..
though i suppose always 1 bad apple"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I was not worried about the syncing as I assume any LCD monitor nowadays is multisync. And I had 1280*768 WXGA in mind.
Does anybody out there have a WXGA LCD monitor like the Sharp LL-M17W1 ?
SR-W7U Component output
By Cingular in forum CapturingReplies: 1Last Post: 19th Jun 2011, 15:14 -
NTSC/PAL and component video
By san2ind in forum Newbie / General discussionsReplies: 0Last Post: 14th Mar 2010, 22:37 -
playing PAL Hi8 tapes in NTSC camcorder output to PAL DVD recorder?
By interlooper in forum CapturingReplies: 2Last Post: 17th Jan 2009, 14:36 -
PAL VCR with true NTSC Output (not PAL 60)
By Area88 in forum RestorationReplies: 31Last Post: 12th Aug 2008, 17:55 -
Premiere PRO - NTSC DV to PAL MPEG output
By SCDVD in forum Newbie / General discussionsReplies: 2Last Post: 5th Mar 2008, 12:06
Statistics
Newest guides
Latest tool updates
New media comments
