I like POWERVCR software a lot. It is fast, good interface, and live transcoding works fine even if you haven’t a monster PIV on 2.8Gigs. But I have a few problems according to changing resolution of captured file. I read a lot of articles in this forum according to “registry hack” presented on lordsmurf’s site: http://www.digitalfaq.com/capture/no...nonatimpeg.htm
I try to do it in practice, but I have a lot of problems, I finally I give up. But maybe other guys on forum have some good ideas!
Here is the problem: I did it on the same way as lordsmurf’s said change hkcm and hkcu registry values. When I want to create a new profile I made the profile as mpeg2 good(copy), I have 480 x 480 or 352 x 480 and 544 x 480 on drop down list, but when I try to transcode in this resolutions, the resolution of output file is 720 x480 (NTSC). The same situaton is with PAL system. I am a little bit confused.
Any ideas?!, Suggestion?!![]()
Thanx,
Luna
Do not cross post - one topic is enough. Other topic closed
/Moderator - Bugster
Hi Luna,
I tried 480*576 (SVCD PAL) and the registry hack worked great. Are you sure you changed the right values ?
Glongo
Is PAL 576 Higher Resolution Than NTSC 480?
By wulf109 in forum DVD RippingReplies: 12Last Post: 1st Dec 2011, 01:10 -
DVP 5990 and 852 x 480 Resolution
By Wanderlustus in forum DVD & Blu-ray PlayersReplies: 6Last Post: 4th Nov 2009, 12:29 -
Newbie question about 720 x 480 dvd resolution
By siratfus in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2008, 17:30 -
DVD resolution is 720 x 480 ??
By siratfus in forum Video ConversionReplies: 4Last Post: 25th Dec 2007, 07:16 -
avi (640*480) to dvd (720*480) without black bars....how?
By Mauserman in forum ffmpegX general discussionReplies: 8Last Post: 10th Sep 2007, 12:25
Statistics
Newest guides
Latest tool updates
New media comments
