My standalone DVD player (Phonotrend) has problems. When I power it on, it will continuously
load and stop successively. I never starts to play the DVD. (Perhaps, there exists some problem with
the circuitry ?? )
I need advise if I could fix the problem.
Is it just one DVD or all of them? If just one, the disc maybe dirty - clean it and you'll be fine. If all of them, take it back to the shop. Don't try to fix it yourself - you'll invalidate the waranty even if you know how to do it.
Its a problem with all the dvd's.
The player has completed its warranty period, and I do not want to get it repaired in a shop. Repairing would be as costly as buying a new dvd player.
I would be happy if I could fix the problem myself.
I've seen some cleaning kits for DVD players in the stores. Maybe that's worth a try.
BSOD - Window doesn't load normal/safe mode
By hoon88 in forum ComputerReplies: 21Last Post: 25th Oct 2009, 08:49 -
Looking to buy a DVD player with a slot load, plus some other features
By Tap2Angle in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2007, 11:36 -
Need slot-load (tray-less) DVD player for home
By jsmithepa in forum DVD & Blu-ray PlayersReplies: 1Last Post: 14th Aug 2006, 20:24 -
DVD player doesn't load properly
By vin in forum Newbie / General discussionsReplies: 1Last Post: 3rd Nov 2002, 15:35 -
Can play DiVX in media player but can't load in TMPGEnc
By z68h in forum Video ConversionReplies: 3Last Post: 17th Jan 2002, 07:28
Statistics
Newest guides
Latest tool updates
New media comments
