Hi, I have downloaded an .avi file which the encoder inadvertently "squished" from it's original source (presumably a 16:9 ratio) to 4:3. So everything looks tall and thin, so to speak. Is there any tool I could use to "unsquish" it and get it back to its original aspect? I tried using Nero VisionExpress 2 but even telling it to use 16:9 (instead of the default automatic mode) doesn't fix the problem. Thx.
Virtualdub, Video, Filters, Resize.
Cheers, Jim
My DVDLab Guides
Sounds like the video IS in 16x9 format because then everyone would be too tall and "thin" looking.Originally Posted by brownstem
Try a media player such as BSPlayer that allows you to change the aspect ratio on playback. Select 16x9 and it should look normal.
IFOEdit, change the 4:3 tag to 16:9 and then play it. Or if it's 16:9, then make it 4:3, just flip it. It may be anamorphic, so try that if all else fails.
To Be, Or, Not To Be, That, Is The Gazorgan Plan
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
how to fix "WARN: unknown mpeg2 aspect ratio 1" in DVD Author GUI
By extent in forum Authoring (DVD)Replies: 10Last Post: 23rd Nov 2009, 07:57 -
Methods to fix "eaten"/crinkled VHS tapes?
By lordsmurf in forum CapturingReplies: 16Last Post: 26th Mar 2009, 14:22 -
Set/Fix QuickTime "atoms"/"flags"?
By rumplestiltskin in forum Newbie / General discussionsReplies: 3Last Post: 22nd Sep 2008, 13:07 -
How to fix "twitchy' or "jerky" .asf files.
By bbanderic in forum Video ConversionReplies: 2Last Post: 21st Sep 2007, 17:48
Statistics
Newest guides
Latest tool updates
New media comments
