Gday, I am a newbie and was hoping someone can help me. I am making backups of my DVD's and I have a Compaq Presario 2500 with a DVD+RW drive. Can anyone tell me what freeware program allows me to actually burn the DVD onto a DVD+R disc.
I use DVD decrypter for the first step and then DVD2Onex for the next step so I have all the menus and movie, but what freeware program allows me to burn it onto 1 disc? I know I can do it all on one disc on my computer at home, but it is a DVD-RW and I use Gear Pro Mastering Edition for the final step.
Any help would be much appreciated, and if anyone knows of what software to use, some steps a tutorial would be great.
Cheers
Thread: Burning with a DVD+RW Drive
hows about doing some searchin 'n readin ?
I hear IMGTools can make an ISO image which can be burnt by DVD Decrypter.If in doubt, Google it.
Yep, I did do some searchin and readin, but as I am new to all this and didnt understand a lot, i thought I would post for some help.
Thanks for the reply, so, this IMG program, do I use it as the third step to actually burn?
Cheers
You should realy read the guides off to the left hand side of your screen.
Here's just one guide I found on what your looking for. Took me a few seconds!
http://www.dvd-guides.com/guides.php...py&name=shrink
I decipher this as IMGTools - step 3, and DVD Decrypter - step 4.Originally Posted by jimmalenko
Don't you ?If in doubt, Google it.
DVDShrink with or without Decrypter.Can anyone tell me what freeware program allows me to actually burn the DVD onto a DVD+R disc
I use the "transcode/create ISO with DVDShrink then burn with DVDDecrypter" method.Originally Posted by Jayhawk
Thanks guys for all your help.
I used DVDShrink and then DVD Decrypter and it worked a dream, no problems at all.
Cheers
Having trouble burning from hard drive to DVD
By becassier in forum Authoring (VCD/SVCD)Replies: 5Last Post: 5th Nov 2008, 12:33 -
problem burning with external dvd drive
By billybob59 in forum DVD & Blu-ray WritersReplies: 15Last Post: 8th Mar 2008, 19:32 -
DVD Burning And Hard Drive Backing up..
By Mastablastacious in forum ComputerReplies: 15Last Post: 19th Jan 2008, 02:30 -
Dvd drive burning very slowwww
By Soixante in forum DVD & Blu-ray WritersReplies: 13Last Post: 24th Dec 2007, 06:55 -
Trouble burning dvd from hard drive
By illyad in forum Authoring (DVD)Replies: 3Last Post: 10th Dec 2007, 11:20
