VideoHelp.com Forum
  1. Guest
    Guest
    Why can a movie be re-authored without the extras and still have the menus work?
  2. Member galactica's Avatar
    please change your avatar.
    perhaps you were not aware that you agreed to this statement
    You agree not to post any abusive, obscene, vulgar, slanderous, hateful, threatening, sexually-orientated or any other material that may violate any applicable laws.
  3. Member p_l's Avatar
    Try CloneDVD.
    Look at arrow 1.
    p_l,
    The question was WHY, not WHAT.
    And a DVD can be reauthored that way because a DVD is an event driven medium. Unless you use something, nothing will happen.
  5. Member galactica's Avatar
    its a simple answer...
    if one removes the extra files [ie the .vob's of the extras] but leaves the .ifo's and .bup's un edited they will assume the dvd is in complete form and the menu will still load as if its a full dvd.
    the problem comes when one tries to access levels of the menu that are not contained on the disk. Typically you will get an error, or a freeze or a smoking dvd player if you choose those options.
    I do this all the time with my backups, just remove the extras, keep the movie and the menu. gives you scene selection and menu navigation but takes out the unnecessary extras info so your movie can look higher quality at 4.4 gigs.
  1. Encore DVD Menu Authoring
    By montgal in forum Authoring (VCD/SVCD)
    Last Post: 29th Apr 2012, 23:24
  2. Authoring DVD without a menu?
    By Humptydank in forum Authoring (DVD)
    Last Post: 29th Mar 2010, 16:55
  3. TMPGEnc Authoring Works 4 - Menu help
    By NotSoEasy in forum Authoring (DVD)
    Last Post: 1st Mar 2010, 02:24
  4. ever had this menu authoring problem before?
    By uglijimus in forum Authoring (DVD)
    Last Post: 22nd Oct 2009, 14:06
  5. dvd authoring with hidden menu
    By VeryNewbie in forum Authoring (DVD)
    Last Post: 21st Jun 2007, 03:21
