VideoHelp.com Forum
  1. if i connect an external source (ie, cassette player) to a stand-alone dvd recorder, will i be able to capture the audio and record them onto a cd-r instead of using a dvd-r/rw or dvd+r/rw? thanks..
  2. Member ZippyP.'s Avatar
    No, it's a DVD recorder.
    So there arent any that can record to vcd or minidvd either?
  4. so that means if i want to connect an external audio source to record onto cd, i must use a standalone cd recorder?
  5. at least for the panny line, it only records to dvdr or dvd ram. Suggest recording to dvd ram and then transferring to pc OR just do it through the pc to begin with (if you have one).
  6. Member solarfox's Avatar
    3390 -- That is correct; you will have to use a standalone CD recorder for the task.
    Set-top DVD recorders are not designed to be a general all-purpose, all-format device like a computer drive is; they're made solely to record DVD's straight from an incoming video feed, and to work as much like a VCR as possible so as not to overly confuse the "average" consumer. If you want to do anything specialized, like VCD or miniDVD (which is not a standard format by any means, BTW), then you'll have to do it on a PC with an appropriate DVD-R or CD-R drive.
  7. Lite-on lvw-5005 can do cd recording.
  1. I can't get my Wharfdale DVD recorder to record in 16:9
    By AndyLGR in forum Newbie / General discussions
    Last Post: 12th Jul 2011, 08:27
  2. DVD Recorder will only record when TV is switched on
    By jiminwatford in forum DVD & Blu-ray Recorders
    Last Post: 18th Apr 2011, 14:03
  3. Can a DVD recorder record stuff from AV?
    By xtube in forum Newbie / General discussions
    Last Post: 12th Apr 2010, 07:29
  4. HELP PLEASE!! Can i record an AV channel on DVD recorder HELP PLEASE
    By Lilman02 in forum DVD & Blu-ray Recorders
    Last Post: 2nd Apr 2010, 14:55
  5. any way to record from TV to DVD recorder?
    By thedriver2200 in forum DVD & Blu-ray Recorders
    Last Post: 10th Jun 2008, 12:37
