VideoHelp.com Forum
  1. Member archaeo's Avatar
    Does Nero CDSpeed tool check only the drive for problems, OR can it also be used for checking a burned DVD for errors? If so, which tool is it that does this? Are there better ones out there for error checking disks?
    thanks
    Click on 'Extra' and there are some tests that check a burned disk- ScanDisk, CD Quality Test.
    You can download the instruction manuel at http://www.cdspeed2000.com/go.php3?link=download.html
  1. Error Checking CD's
    By Nitro89 in forum Audio
    Last Post: 8th Nov 2009, 23:58
  2. Quality Checking copies
    By OldPhart in forum Media
    Last Post: 1st Oct 2008, 07:31
  3. Error checking software?
    By Lucifers_Ghost in forum Computer
    Last Post: 17th Mar 2008, 08:01
  4. Error checking software
    By JimboM in forum Authoring (DVD)
    Last Post: 26th Feb 2008, 13:18
  5. Tool "Alert Me" - MySQL error
    By daamon in forum Feedback
    Last Post: 30th Sep 2007, 03:48
