I need to know if there is a command line to delete C: while windows is running? Revenge can be a beautiful thing.
Thread: command line question
If at first you don't succeed; call it version 1.0
If windows is running likely it will not let you delete the windows files. Its called Windows File Protection.
Of course the version fo windows matters, as does the fact that I cant think of a single reason not to just format a drive the normal way.
Theres the reason.
And it would be running XP Home Edition.If at first you don't succeed; call it version 1.0
Not saying their is not a way, but with Windows XP it should not allow itself to be completely deleted.
Can't be done. I've tried it. However, if you have another computer, you might be able to set the drive you want to format to slave and use the second computer to format the 'slave' drive. Lot of trouble though.
I know your problem, Windows XP doesn't cooperate as well as Win98 did. I miss the old "format C:/s".If it works, don't fix it.
Don't know how that smiley face got there, that is supposed to be a forward slash.
method 1Originally Posted by b1tchm4gn3t
Use a boot floppy or a bootable CD
Place a blank ghost image on it
use the autoexec.bat to start ghost and use the blank image.
It will clear the HDD in less than a few seconds (CD method)
By time they realize what's happening, it's already done
method 2
create a script that set an AT command to format the drive at next boot up
It will not delete everything, but enough to require a new install from scratch
Command-line command for fixing AVI?
By timur in forum ffmpegX general discussionReplies: 1Last Post: 23rd Sep 2009, 02:23 -
How do I use Lame command line?
By rocky12 in forum AudioReplies: 37Last Post: 16th Jul 2008, 21:33 -
command line
By exekutive in forum ffmpegX general discussionReplies: 22Last Post: 1st Jun 2008, 23:44 -
DGPulldown and Command Line Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 9Last Post: 24th May 2008, 20:28 -
Access to command line
By ktwbc in forum ffmpegX general discussionReplies: 1Last Post: 1st Dec 2007, 12:31
