I am using Pinnacle Impression DVD Pro to author my DVD's. It's a great program but it does have some flaws. When you author something, if you press next on the DVD remote, it goes to the next title (even if you linked it to go back to a menu).
I am trying to fix this problem with Ifoedit 0.96. Would the following HEX code for a cell command trigger the post command (which goes to the menu) after pressing the next button on the last chapter of a title?
HEX CODE for cell command:
20 01 00 00 00 00 00 0D
After spending 2 days of burning, and reburning, and reburning on DVD-RW discs, I am a little tired of trying to get something to work. Any help would be greatly appreciated. I got a member for MPUCODERs site but the information does not have have enough basic information for us newbies.
I got the hex code from:
http://www.dvd-replica.com/DVD/linktailpgc.php?p=1
Any help would be greatly apprecaited.
halogen
Okay, so that hex didn't work. Any ideas on how I can fix this problem I'm having?
Change the post code that does a Jump Title to Jump menu.
No need to add, just edit.
Some players can jump to the next title when you press "next" while playing the last chapter of a particular title. It's a useful feature if you don't have a menu. There's nothing wrong with your authoring application. If you don't want this to happen you can put a user restriction in the last cell on the "next" button.When you author something, if you press next on the DVD remote, it goes to the next title (even if you linked it to go back to a menu).
Proper MKV Format for Playback on A Media Player
By gonwk in forum Newbie / General discussionsReplies: 3Last Post: 18th Aug 2011, 20:59 -
Extract Image from WMV using HEX values?
By phatz in forum Newbie / General discussionsReplies: 4Last Post: 7th Jun 2009, 14:44 -
What's the proper way to match clocks for live video playback
By dxm007 in forum ProgrammingReplies: 0Last Post: 5th Apr 2009, 14:44 -
Steps to ensure best video shoot
By bowmah in forum Newbie / General discussionsReplies: 4Last Post: 26th Sep 2008, 22:17 -
What program will ensure a DVD will play all the way through?
By kozara in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 14:33
Statistics
Newest guides
Latest tool updates
New media comments
