VideoHelp.com Forum
  1. Major Prob..
    have followed all the guides
    Have now smooth NTSC Mpeg2 DVD format
    But Tmpgenc won't author it..
    I've been at this 2 weeks now
    PLEASE PLEASE HELP
  2. Member bugster's Avatar
    Any ideas why, an error message perhaps?
    help us to help you, we need much more detail on how you produced the mpeg and encoder settings used as well as any error messages TmpGenc DVDA is giving you otherwise we would just be guessing.
  3. Member bugster's Avatar
    I wouldn't normally post copies of PM's in a publ;ic forum, but there is nothing private about this:
    Sorry have not been more clear..
    I'm at work at the mo
    yes it comes up with ilegal something or other
    But it's ntsc film movie
    done everything in the posts..
    i've read something about flags
    Now i can change these in tmpgenc
    but not sure
    It sounds like you need to set the 3:2 pulldown flags. You can do this in TmpGenc but if you have already encoded you can use pulldown.exe (and its gui) to do this to the .m2v file.
    BTW, keep your technical questions and answers to the forums. The wider audience gives you a much better chance of getting the answers/advice you need.
  4. It's the flags that i don't understand mate
  5. i got the puldown .exe
    but when i executed it it just flashed up
    and did nothing
    is it software you can use or does it execute in the registry
  6. Member bugster's Avatar
    and did nothing
    It is a command line app. If you don't know how to use command line apps I believe there is a available gui for it.
  7. Now it's getting complicated
    can you help with this..
    what is command line
  8. This pulldown exe programme..do I just add the mpeg 2 file and it will add it & then can I author it.......
  1. Replies: 0
    Last Post: 31st Oct 2010, 15:53
  2. Replies: 6
    Last Post: 21st Dec 2009, 09:45
  3. which muxer handles NTSC 704x480 2.21:1AR 29.97fps mpeg2
    By halsboss in forum Video Conversion
    Last Post: 3rd Mar 2009, 20:39
  4. Replies: 6
    Last Post: 23rd Oct 2008, 13:59
  5. 24fps HDV (NTSC) to 29.97fps DV (NTSC)
    By vodnick in forum Camcorders (DV/HDV/AVCHD)
    Last Post: 3rd Jan 2008, 06:36
