VideoHelp.com Forum
Results 1 to 14 of 14
  1. hi. i try to convert the avi file to 25 fps... when idid it i save the wav and change him with ac3machine... and i change the movie too...
    but when i try to add subtitle and add the wav file and the movie together the sub comein with the subtitle, but the sound not comin in the time he need to.
    when i convert the movie he was short of like 5 mins but the sound was short of like 10 mins.. maybe its need to be like that but its not good when i add them both together.
    what am i need to do? 10x.
  2. Member mats.hogberg's Avatar
    Seriously - you're making absolutely no sense at all.
    What do you mean by that? All you've told is that you have an AVI file that's 23.976 fps, that you want in 25 fps, but somewhere the audio gets out of sync...
    What do you have (Use GSpot to tell, and if you don't understand what GSpot tells you, just post a screen shot of it) and what do you want? (AVI? VCD? DVD? SVCD? Other?)
    /Mats
  3. man i dont know what this program doin.... i want to convert to vcd with subtitle... but maybe the reason to the sound its not the way i change it... because i just convert one more movie and when i convert to vcd with tmpgenc te sound not comein in the time again.,. and in the avi file he is.
  4. in TMPGEnc load the video and then load the extracted WAV as your audio source. encode them both together, to either a system stream or elementary streams. TMPGEnc will adjust the audio as well as the video. I don't know what people have against using the audio processor in TMPGEnc. so long as you are doing something simple with it the program works fine, especially with WAV as your source.
  5. thats what i did... but its not matter because the sound was 44 minutes and the video 48...
  6. what exactly did you do with AC3Machine? does the audio file output from TMPGEnc match the length of the video output? if so then you are doing something wrong in AC3Machine. try using FFMpeg GUI instead to convert to AC3. Its a much easier interface and hard to mess up.
  7. I'm a Poll Super Moderator johns0's Avatar
    Use besweet to change the audio from 23.976fps to 25fps,this will put the audio back in sync as long as there is no errors.
    Ben Johnson-I didnt take any stereos!
  8. Member mats.hogberg's Avatar
    What I do is this:
    Extract audio with VirtualDub. Decode to wav (with what depends on audio codec)
    Change AVI frame rate with (you guessed it!) AVIFrate
    Make wav shorter either with GoldWave Timewarp function or WavWorks.
    Use 25 ps AVI as video source, and shortened wav as audio source when encoding. Works like a charm.
    The
    part sounds like you've done a 25 to 23.976 frame rate conversion on the audio instead of the other way around...
    /Mats
  9. Member rhegedus's Avatar
    You probably don't need to change anything since most PAL dvd players will play 23.976fps NTSC without any problems.
    Just use the VCD NTSC Film template in TMPGEnc and it should work out.
    Regards,
    Rob
  10. Member mats.hogberg's Avatar
    Most is the key word. Mine doesn't (plays jerky - just like a bad frame rate conversion) , that's why I've learned all black magick involved in 23.976 to 25 fps conversions...
    But I agree - try a 23.976 NTSC disc first. If it works (and chances are pretty good) on you PAL player, you've saved yourself a lot of trouble!
    /Mats
  11. Change AVI frame rate with (you guessed it!) AVIFrate
    idont know how to use these 2 programs.. i try to but i dont find the way to change there frame there... in the avi program i change the 1 to 25.000 but its tellin me its cant read the file. help plz :>
  12. Member mats.hogberg's Avatar
    ?? Never had AVIFrate fail me, and I can't see why it should either, if it's an AVI you're working with at all! You should see "23.976" in a text box right before where it says "fps". You type in "25.000" instead and hit "Apply". After confirming that this is what you want to do, the AVI should play back at 25 fps.
    But be sure to perform this after extracting the audio track, as I'm not sure how VirtualDub handles the audio if you've changed the fps already.
    /Mats
  13. ohh i download the wrong program... its takein only a sec its can be?(i mean the convert)
  14. Member mats.hogberg's Avatar
    It takes no time at all - like I said, it's just a matter of altering one little value in the AVI, that tells the software how fast it should display the frames.
    /Mats
  1. To synchronize 29,970 audio fps for 23.976 fps
    By DruidCtba in forum Newbie / General discussions
    Last Post: 27th Sep 2009, 12:01
  2. Sync 29.970 FPS audio to 23.976 FPS video?
    By LCO1971 in forum Newbie / General discussions
    Last Post: 13th Sep 2008, 15:23
  3. How to convert a video of 120 Fps to... well 23.9fps or 25 fps or 30 fps
    By Chuba753 in forum Newbie / General discussions
    Last Post: 6th Jun 2008, 19:17
  4. Converting 23.976 fps to 29.97 fps
    By wasimismail in forum Video Conversion
    Last Post: 14th May 2008, 18:26
  5. Converting 23.976 fps to 29.9 fps
    By zanos in forum Video Conversion
    Last Post: 13th Apr 2008, 09:03
