I am about to purchase a new monitor. During the research process, I noticed something as 0.25mm - 0.28mm Trio Dot Pitch technology. Does anyone know anything about this? What does it really mean?
Any information is greatly appreciated.
A simple defintion of the term:
Trio Dot Pitch
The distance from the center of one dot, or in the case of a tension mask type display, one bar, to the center of the dot of the next closest dot of the same color. Dot pitch gives a general idea of the monitor's ability to produce sharp images: the smaller the dot pitch, the sharper the image. It must be noted, however, that the focusing ability of the display is also an extremely important determining factor.
Obviously, the closer the dots are together, the finer the "grain" of the picture will be, that's why when shopping for a monitor, you should look for the smallest dot pitch available in the price range you are in (among other criteria). On flat shadow mask CRT design, the dot pitch is variable.
For example, 0.25mm trio dot pitch = 0.24 to 0.28mm variable dot pitch and 0.20 to 0.25mm horizontal.Ethernet (n): something used to catch the etherbunny
dot (pixel) pitch and resolution for a LCD monitor - accessibility question
By moniia in forum Newbie / General discussionsReplies: 5Last Post: 19th Feb 2011, 15:18 -
Monitor - "can't play 24p video" . . . Is this true?
By bweath in forum ComputerReplies: 10Last Post: 12th Jun 2010, 14:02 -
$$$ for help removing high pitch "ssss" sound
By paudieshea in forum AudioReplies: 15Last Post: 20th May 2010, 18:52 -
"Audio monitor" on Panasonic AG-1980?
By moxiecat in forum RestorationReplies: 13Last Post: 25th Oct 2009, 12:10 -
Nero Showtime shows black "screen" on secondary monitor.
By fk in forum Software PlayingReplies: 2Last Post: 12th Jul 2007, 15:06
Statistics
Newest guides
Latest tool updates
New media comments
