Hey, i was wondering what the name of the firmware patch i need is to change my booktype to either dvd-r or dvd-rom.
Found a lot of different firmwares, and im not sure which one i need.
http://etna.rpc1.org/nec/index.html < Has a list of firmware hacks.
I could use this information as well. I have the TDK 420N. Thanks!
Its probably the HP300 fw you two are looking for.
But if I had a Nec1100 I'd flash it to Nec1300.
Do a forum search at rpc1.org for "nec1100"
You'll get hundreds of threads on this one.
http://forum.rpc1.org/search.phpYou stop me again whilst I'm walking and I'll cut your fv<king Jacob's off.
DVD burner only burns DVD-RW now and firmware problem.
By yocahu in forum DVD & Blu-ray WritersReplies: 2Last Post: 14th Mar 2010, 21:23 -
Is it possible to flash firmware onto a non-original DVD burner???
By suomalainen in forum Newbie / General discussionsReplies: 1Last Post: 12th Dec 2009, 16:17 -
I have an Aopen Dvd Burner, how can I set booktype in imgburn?
By frieday in forum Authoring (DVD)Replies: 13Last Post: 3rd Nov 2009, 05:30 -
NEC ND-3500AG DVD RW DL burner doesn't recognize blank DVD's
By renegade431 in forum DVD & Blu-ray WritersReplies: 38Last Post: 8th Feb 2009, 06:16 -
Need to change Region Code for NEC NDRV-60
By alexspag in forum DVD & Blu-ray RecordersReplies: 4Last Post: 11th Dec 2008, 08:19
Statistics
Newest guides
Latest tool updates
New media comments
