2 problems: I want to burn an audio cd of the audio file from a dvd made from a Panasonic dvd recorder, but the audio seems to be buried. Any ideas?
Also, I have a dvd (made from a different recorder) which only had the LEFT audio recorded on it. Using a computer (not a dvd player hooked up to a dvd recorder), how could I re-burn the dvd using the LEFT track for both LEFT and RIGHT tracks?
Vobedit will demux the audio and video from a VOB file, or one of the ripping programs (smartripper, dvd decrypter?) will rip a DVD into elementary streams.Originally Posted by spiritgumm
Demux the audio and video with VOBedit. Load the audio into Goldwave.Also, I have a dvd (made from a different recorder) which only had the LEFT audio recorded on it. Using a computer (not a dvd player hooked up to a dvd recorder), how could I re-burn the dvd using the LEFT track for both LEFT and RIGHT tracks?
- First blank out the right chnnel.....Edit>channel>right, edit>select all, edit>cut
- Then copy the left channel to the right...edit>channel>left, edit>select all, edit>copy, edit>channel> right, edit>paste. After that's done you can save out a new wav file. You can convert your wav to MP2 (besweet) or AC3 (ffmpeggui) then feed your audio and video back into an authoring program and burn."Art is making something out of nothing and selling it." - Frank Zappa
Thanks, Zip, I'll give it a try (though it sounds abit challenging).
If you've never used the programs before, I agree. I did it as a test while composing my original reply.Originally Posted by spiritgumm
Get audio track from DVD Extra instead of film sound track in VIDEO TS
By Josephine in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2010, 12:25 -
Problem with PCM Audio track when Burning DVD
By darnhs in forum DVD RippingReplies: 7Last Post: 11th Aug 2008, 21:07 -
Problem audio track
By didikai in forum Newbie / General discussionsReplies: 1Last Post: 11th Mar 2008, 10:45 -
Video audio track cleaning problem
By efiste2 in forum AudioReplies: 1Last Post: 9th Feb 2008, 14:49 -
Panasonic DVD Recorder and DVDRAM copying problem
By lee harvey oswald in forum Newbie / General discussionsReplies: 7Last Post: 5th Sep 2007, 00:52
Statistics
Newest guides
Latest tool updates
New media comments
