hey,
i've had this player for probably 6 months or so, and just today we started having problems with it. it will load up the dvd menu, but then no matter what button you push, it will automatically select the option one down from what its on. for example, when it brings up the play movie/chapters/audio menu, any button you push on the remote will go to chapters, and then once you are in there, any button will select chapter two. the unit itself seems to work fine, but since almost everything is controlled by the remote i really can't test it. thanks for any help!!
mike
Results 1 to 1 of 1
Remote Control Problem with new Sony SR500H DVD player
By Bass Cadet in forum Newbie / General discussionsReplies: 3Last Post: 27th Jun 2011, 12:56 -
sony dvd recorder remote problem
By tattoojo in forum DVD & Blu-ray RecordersReplies: 4Last Post: 15th Mar 2011, 11:26 -
Help i'm a newbie need the AMW Vsonic 120 dvd player multiregion hack code
By skeleto2005 in forum Newbie / General discussionsReplies: 0Last Post: 15th Dec 2009, 20:53 -
Remote Control Problem - Pioneer DVR-330-S
By wmedia in forum DVD & Blu-ray RecordersReplies: 4Last Post: 25th Mar 2008, 07:31 -
LG DVD Hacking / Remote
By Spikey in forum DVD & Blu-ray PlayersReplies: 0Last Post: 28th Aug 2007, 05:33
