I apologize for lenthy post..
Please help..I'm facing some weired problem..I don't know what's going on?? Here it is:
My PC SPEC:
Pentium Dual Xeon 2.0GHz
1.5GB Rambus RAM
ATI Fire GL4 Pro Video Card (128MB DDR)
(3) 17GB SCSI Drives (one for OS & two for storage/Data drives)
(1) 200GB IDE drive..
Running under Windows XP Pro..
Here is the Problem:
The PC works great except when I render the project in Sony vegas4.0e (to NTSC DV Format) [and encode the NTSC DV avi file in Canopus Proceder..]![]()
The PC stalls temporarily for a minute or two..and then renders for a minute or two and this cycle goes on and off until it finishes rendering the project. When the rendering pauses, the computer freezes up the rendering timer as well as the system time clock in the bottom right corner of the screen.
During my observations, I found out that the PC freezes up on & off ..Again this happens only when I render in Vegas 4.0e and encode the avi files in Canopus Encoder 1.5 ...and my rendering/encoding time increases by double...![]()
P.S. I am using the one of the SCSI data drive as temp/pre rendered drive ..
Please help me what is going on???![]()
Thanks in advance for your suggestions....
Voodoo!!!
First of all, I'm salivating a bit over your PC descriptionOriginally Posted by matrix_voodoo
I had a similar experience running Procoder in Win2K, but mine wouldn't recover ...just lock up. I never did get it working right.
Heat.
It sounds like something is reaching a critical temperature and stops working until it cools down slightly. You're putting a mighty good strain on your system when you're encoding. How satisfied are you that heat is being properly managed in your system? -
I'm working on a 2000th post special thread right now.Originally Posted by freestyler
Thanks guys for the replies..
I have total of 4 fans (1) front, (2) rear and (1) on side and it takes care of the PC's temprature..Of course, the rear fans shoot out hot air but well around the room temparature..I have checked in BIOS after leaving computer on for more that 30 minutes and the temperature was well below
the worst case...Well, I noticed there one thing though..The voltage level were staying little lower (about .3 to .6V) than normal..Do you guys think that might be the problem???
Computer does it jobs but takes almost double time unncesserily. Any suggestions or advice still welcome you veterans...
Thanks,
Voodoo!!!
Computer crashes when rendering video
By David Bruno in forum Newbie / General discussionsReplies: 20Last Post: 2nd Feb 2011, 19:33 -
my computer freezes
By bits27 in forum MediaReplies: 20Last Post: 9th Sep 2009, 00:35 -
ImTOO - COMPUTER FREEZES
By orpey in forum DVD RippingReplies: 7Last Post: 11th Oct 2007, 05:57 -
Terminilogy: Rendering vs Encoding
By SCDVD in forum Newbie / General discussionsReplies: 5Last Post: 13th Jul 2007, 23:44 -
computer freezes when encoding
By persiani in forum Authoring (DVD)Replies: 3Last Post: 17th Jun 2007, 18:23
