I cant find anything here on a coverting software that can convert Real Video to mpeg or avi.
Anyone?
-hyper
There is a program called Trina that will conver rm's. I think that it is d/lable in the tools section. Only problem is that it converts it to an uncompressed avi, which is very, very large. If anyone knows how to convert from rm to mpg or avi instead of an uncompressed avi using Trina, please post a reply.
I couldnt find trina though...
-hyper
that's because it's called tinra
wht ive been doing is using a prog. called snagit (check tools) and grabbing the video from realplayer. unfortunately the prog doesn't seem to let me use huffyuv, so captures are uncompressed. I can use DivX though, which works reasonably well. i tried using tinra, and i don't like it. no options at all, and messy to use, as you have to open the resulting .avi in vdub and alter its framerate, then you end up with the sound out of synch and - it's just messy. use snagit/some other screen capture software.
Simple issue, cannot find program to do it..need to split AVI with a FF
By serpa4 in forum EditingReplies: 17Last Post: 4th Nov 2009, 23:19 -
simple avi editing program
By twotle in forum EditingReplies: 5Last Post: 7th Feb 2009, 21:19 -
open source program for converting .avi and/or mpeg-2 to .f4v
By lapchumic in forum Video ConversionReplies: 2Last Post: 9th Jun 2008, 12:10 -
Simple MPEG-2 to DV-AVI converter
By TPFKAS in forum Video ConversionReplies: 4Last Post: 18th Oct 2007, 06:27 -
Is there a good simple program to encode .avi's to mpeg?
By modartist in forum Newbie / General discussionsReplies: 7Last Post: 12th Aug 2007, 20:35
Statistics
Newest guides
Latest tool updates
New media comments
