Hi,
For those interested on using Proshow Gold (version 2 is out ) in order to build slideshows and burn on DVD ( and also as VCD or SVCD ), I would like to start this topic so we can exchange tips and tricks on using this software.
I will start with the first tip, taken from another thread, applied when using the "CREATE VIDEO" dialog box :
In order to achieve better video quality , try unchecking the "Apply anti-flicker filter to video" option .
I would like to hear your opinion about the "Desaturate images to" option and it's setting ( percentage ).
Also, has anyone tried using the custom setting for DVD video, in order to set the bitrate higher than the default 7500 setting ( although I think this is pretty much satisfying ) ?
I am sure there will be many other issues to discuss and exchange ideas.
Please post your findings and suuggestions here.
Thread: Proshow Gold Tips & Tricks
I hope I am not the only one around using ProShow Gold 2.
I'm using the Create Video File option, in order to create the MPEG2 file which I will then import on the DVD authoring software that I use.
On "Video Format Preset" I chose the Custom option instead of the DVD option ( which has fixed value for bitrate ). I then set the bitrate to whatever value I like.
BUT the final MPEG2 file has audio as 44KHz instead of the standard 48KHz produced when I choose DVD option, even having made sure that the format is set to MPEG2 .
This causes the MPEG2 to be rejected and reencoded on my DVD authoring software.
Anyone know how to make Proshow set audio as 48KHz when working with Custom option ?
Also, I would like to hear your opinions about the best setting (value ) for the "Desaturate images to" option.
I'm curious if you've used MemoriesonTV and if so, how does ProShow Gold compare?
Yes I have tried MOT.
But I'm not so interested on features like Ken Burns effects and others.
My main goal is to produce a DVD with the best qaulity possible, and menus to access specific groups (albums) of photos.
You can find comparisons between MOT and PSG here :
http://www.dvdrhelp.com/forum/viewto...=875412#875412
Hello ,
Can anyone using Proshow try the settings above for Create Video File option and check the resulting audio frequency ?
I tried it and got this, i will try some other tests
MPEG-1 352x240 29.97fps CBR 1150kbps, Layer-2 44100Hz 192kbps
The settings I used :
Video Format Preset : Custom
Format Settings :
Format : MPEG2
Framerate : 29,97 Bitrate : 8500000
Resolution : 720x480
Audio : 224Kbit
Display :
Aspect Ratio : 4:3 (TV)
Encoding Quality : High Quality
Desaturate Images to : 80% : Enabled
Apply anti-flicker filter to video : Disabled
Anyone Own 101 Tips & Tricks For Sony Movie Studio?
By V Bot in forum Authoring (DVD)Replies: 3Last Post: 7th Feb 2011, 19:43 -
SONY HDR-FX1 Forums? Tips & Tricks? Tutorials?
By foochuck in forum Camcorders (DV/HDV/AVCHD)Replies: 8Last Post: 22nd Feb 2008, 07:39 -
Proshow Gold Chapters
By marioval in forum Authoring (DVD)Replies: 1Last Post: 30th Oct 2007, 12:38 -
Creating the best MKV hd video discs... Tips & Tricks? HELP PLEASE
By Toaster in forum Authoring (DVD)Replies: 1Last Post: 29th Aug 2007, 22:30 -
Tips and Tricks
By squallheart in forum Video ConversionReplies: 11Last Post: 9th May 2007, 13:50
