Do I need a special software to transfer my tv taped footage to DVD? Can I do it with Virtualdub or something? What type of cable might I need to use to connect my VCR to the computer? If anyone knows the answer please let me know thanks. The reason why is cos I am getting a DVD 558 recorder and I will no longer have further use of my VCR. Thanks for your time![]()
You need a capture device, capture software, authoring software and burning software as a bare minimum. Read the "How To" section at the upper left of the screen. Then look through the "Capture Cards" section and read up on some of the features and compare. Then figure out what apps the card comes with and what you'll need to get ahold of after that.
<----- do some research and get back to us... you question is far to general to even start answering...
If a DVD 558 is a standalone DVD Recorder which I assume it is. You just link your video to it and record directly to DVD . That's it. Just like linking to vcr's together for tape to tape copying.
If it is recorded TV footage you want to backup then you will have no copy protection issues.
It's an awful lot easier than doing it on your PC and there is nothing else to buy exept maybe a lead to link them together.
"Learn from other people mistakes , it's quicker"
Magic.
Answers to Common Video Questions:
Best blank discs • Timebase Corrector FAQ • Best VCR for capturing • Help restoring video
Hi-8 tapes need to transfer to DVD
By jbitakis in forum Camcorders (DV/HDV/AVCHD)Replies: 1Last Post: 11th Apr 2011, 03:42 -
I have some VHS tapes that I want to transfer to a computer hard drive.
By marada in forum CapturingReplies: 15Last Post: 30th Nov 2009, 08:35 -
A good recorder that will transfer difficult VHS tapes?
By siberwolf in forum DVD & Blu-ray RecordersReplies: 20Last Post: 12th May 2008, 08:15 -
What I want to do: Transfer/capture old VHS and Hi8 family tapes.
By Boomer1948 in forum CapturingReplies: 7Last Post: 4th Jan 2008, 22:19 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 4Last Post: 4th Oct 2007, 19:19
