I loaded dvd rebuilder, but I have a problem, when I hit rebuild it comes back with a error message "There is nothing to do! DVD-RB couldn't locate appropriate files in the working directory! You must prepare and encode first. Aborting." What am I doing wrong, what other software do I need, how do I set up the other software?? I have cce 2.5, rejig, and quenc installed and set up. In the directory there is a d2vavs and a video ts folder.
Steve
Thread: dvd rebuilder
Have you ripped your files from the DVd and put them in a folder? let's us know if you can get it to work. I got further but also error message.
Hi Vanderlow,
Yes I did, it gets to the remurge part then gives the error. I wish there was better error checking with this program.
What encoder are you using? I am using cce v1.5.0. This program has some bugs to be worked out for sure!
Steve
Now if I use QuEnc .45, I get a AVS File is not outputing (Use Convert to YV12() at the end of script.
http://forum.doom9.org/showthread.ph...threadid=73050
that is the official Bug Reports thread.
http://forum.doom9.org/showthread.ph...threadid=73051
That one is for general discussion.Boy do I love my avatar!
DVD Rebuilder overflow
By RickyPinxt in forum Video ConversionReplies: 14Last Post: 27th Apr 2011, 14:43 -
DVD in BD Rebuilder!!!
By fjmr in forum Blu-ray RippingReplies: 3Last Post: 18th Aug 2009, 10:22 -
dvd rebuilder
By dvd1304 in forum User guidesReplies: 2Last Post: 20th Jul 2009, 12:31 -
DVD Rebuilder (free)
By maja_the_bee in forum DVD RippingReplies: 1Last Post: 27th Jul 2008, 10:12 -
problem with dvd rebuilder!
By jonkiller in forum DVD RippingReplies: 1Last Post: 2nd Aug 2007, 08:58
