New in Version 1.1.52 : 03/27/04
*New feature*
- New "Preview / Test Video" option enables you to play your video
before or after you install a codec to see if the video is working
properly.
- Option to keep window on top of other windows.
- Live Update now checks, and notifies you of updates.
You are also able to see what is new, and instantly download updates.
- ToolTip's are attached to main buttons.
- New image formats to reduce .exe size.
- Tweak menu handling to prevent window overlaps.
- Updated "How to use" instructions.
- Modified text strings, added "Audio Options" & "Video Options"
Review, screen shots, and comments at url below.
http://www.dvdrhelp.com/tools?tool=572#comments
Its impossible to download this thing as far as I can tell. No luck. All I get is an empty page.
Those who have popup blockers may experience problems. Please disable any popup blocking, our site does not display popups, however your download sources will popup in a new window.
If you do not have a popup blocker then we have a problem, and we appreciate your info. We will resolve this issue as soon as possible.
If all else fails you may download it from this direct link below.
A direct link will be added to the site as well for those with your issues.
Thanks again for reporting the issue.
http://www.afreecodec.com/VT/afreeCodecVT_Setup.exe
How to disable Microsoft Update, not Windows Update?
By ukb007 in forum ComputerReplies: 17Last Post: 8th May 2011, 15:52 -
How to Update Your Duplicator's BIOS. you need to update
By krrish in forum DVD & Blu-ray RecordersReplies: 1Last Post: 29th Apr 2011, 12:02 -
Please update me on sw :-)
By boeniz in forum DVD RippingReplies: 7Last Post: 13th Apr 2011, 08:15 -
How to manage tool update email notifications?
By JohnnyBob in forum FeedbackReplies: 2Last Post: 28th Jun 2010, 21:48 -
i'm out of the loop..could someone update me?
By 91rtstealth in forum MacReplies: 6Last Post: 6th Nov 2008, 17:48
Statistics
Newest guides
Latest tool updates
New media comments
