I was wondering if you use the customise option and remove titles from the disc, e.g interviews etc... does that affect the way the dvd plays on standalones. I know usually if you want to remove titles its a slightly longer process using ifoedit, Or does DVD Copy 2 correct all that for you?
Results 1 to 10 of 10
I haven't tried the software yet, but according to this guide: http://www.dvdrhelp.com/guides.php?guideid=562#562 it seems like you can remove unwanted titles.
I decide to try this proggy,after all the hype..
its terrible ,even PowerDvd wont read the Dvd after removing few titles
First time my sony players refuse to play a disc..
it work on a cheap player,picture was terrible,just delete it from my
box...
it will freeze at the tile removal point..NFG
What version did you have problems with m8 ?Originally Posted by GangstaMo
I have been palying with Version 2 (Platinum) and so far the output seems very good, (better than DVD Shrink) and it's fast. Plays well in Power DVD 5 also.
Has anyone managed to find a way to remove the "nag screens" and manin menu? My Sony freezes after the first nag, but I just hit menu and it started fine.
Phil,i use Ver2 Plat
i test a Music video ,i rip few songs at random,just to test the
customize option on a DVDRW..
I upgraded from gold 1.2 to platinum 2,and using the customise,and none of the disks play in ifoedit,or my settop dvd player.I e-mailed them,and they are looking into it.Everyone who has problems should e-mail tech support,and maybe they will realize there are bugs in this program.I went back to gold and it works just fine.
This will be a good program when the flaws are fixed.
Brad Millerbmiller,ont.canada
I too,have tried this app
vers.2 was supposed to fix things
seems ever so complicated for $80
Makes the best dvds if you go movie only
but u have to rip using shrink, cause
the audio issue is messed up, never
know which youll get....cheers
ps, dont try to uncheck nag screens
cause itll mess things up...
Late reaction, but anyway same problems here using version 3. When using customise to get rid of some nag-screens or trailers, discs won't play. Customise feature doesn't work at all..
There are no stupid questions, only stupid people.
Thanks,i was curious how 3 would work.An application to stay away from.
bmiller,ont.canada
How much do you customize your desktop?
By johns0 in forum PollsReplies: 6Last Post: 4th Oct 2010, 16:38 -
Worth upgrading from sony platinum 8 to platinum suite 10?
By helper in forum EditingReplies: 0Last Post: 30th Jul 2010, 00:30 -
Customize a mkv file
By binnyshah in forum Video ConversionReplies: 13Last Post: 2nd Jul 2010, 12:21 -
DVDFAB Platinum 6 . . . need a basic primer for 1) CUSTOMIZE + 2) save ISO
By MISS CHIEVOUS in forum DVD RippingReplies: 14Last Post: 25th Oct 2009, 14:32 -
Help, Problem with Intervideo dvd copy 5 platinum
By heman28 in forum DVD RippingReplies: 2Last Post: 3rd Jan 2008, 20:12
